fuse harness/extender
scavenger
Member - Posts: 8
Posted: January 24, 2012 at 10:08 AM / IP Logged
I'm sure that's not the correct term but on a vehicle I was working on last week, there was a little piece of metal that slipped on one of the legs on a mini fuse and brought the power up beside the fuse so a wire could be attached to it.  What's that called and where to you buy something like that?  In fact, what online sources do you use to buy anything related to 12V electrical (fuses, heatshrink, butt connecters, etc).  My local source doesn't carry much and they seem expensive.
offroadzj
Gold - Posts: 2,043
Posted: January 24, 2012 at 1:16 PM / IP Logged
I believe they are called fuse taps. But be VERY careful using them... they can end up spreading the internal terminals of the fuse box and a normal fuse will no longer make proper contact.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted: January 24, 2012 at 5:29 PM / IP Logged
SPUR FUSE, in the US, try Metra or Scosche, don't use for alarm work, too obvious.
scavenger
Member - Posts: 8
Posted: January 24, 2012 at 7:32 PM / IP Logged
Funny you should mention that.  This fuse tap was on the fuse panel feed for a snowplow that I bought last week (used).  I had to un-install it from the seller's truck.  I removed the fuse and fuse tap from that truck and when I went to install it in mine, it was very loose.  I was worried it would fall out with any vibration at all.
Thanks for the replies.
Platinum - Posts: 13,725
Posted: January 24, 2012 at 8:39 PM / IP Logged
fuse harness/extender -- posted image.
The older fuse taps did have a tendency to spread the contacts inside the fuse slot.  Ones as pictured above do not have this problem.  Notice the slot cut into the top of the pic.  The leg of the fuse slides through that opening.  So only the thickness of the fuse blade is all that goes into the connection.
Posted: January 24, 2012 at 8:41 PM / IP Logged
Posted: January 25, 2012 at 12:36 AM / IP Logged
AS we mentioned in your other thread, run the relay fuse directly to the battery with a ring terminal.
Posted: January 25, 2012 at 12:43 AM / IP Logged
Sorry, I thought of the wrong thing, don't use the ones pictured, they will be loose.
armour auto.com, main catalogue, page 234
Posted: January 25, 2012 at 4:12 AM / IP Logged
You can use the one in the first picture.  But as stated do not use the type in the last picture.
scavenger
Member - Posts: 8
Posted: January 25, 2012 at 8:29 AM / IP Logged
That's strange.  The fuse tap that I removed was the type in the first picture, yet it was a loose fit in my fuse panel.  Just a coincidence I guess.
Thanks for all the replies. fuse harness/extender -- posted image.
Saturday, January 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
