Aladdin A-2000 Install Help
nsimbu
Posted: May 01, 2003 at 5:49 PM / IP Logged
Im installing a Aladdin A-2000 that I bought from rx4speed on a 2002 RSX-S Manual. I have most [70%] of the wires connected. But since this is my first time installing a security system, I have no idea how to do these other ones, such as the door locks, clutch bypass switch, starter interrupt, and parking lights that i think require diodes. I am very confused and am debating whether I should continue to try to install this or just have a shop do it. Also, when I had the alarm working and I had it arming and disarming, why is the range incredible horrible. It works for about 5 feet away from the car and then thats it. I even cut the resistor and still nothing better. I have the communication module on the visor up high also. My car is in the garage and it doesn't even work from right inside the door.  I would like to be able to finish this but don't have enough knowledge on how to do the more specific wiring.
Da Kydd
Posted: June 01, 2003 at 7:50 PM / IP Logged
I'm an installer/sales in ATL/GA area...so hit me back with you "challenges".
