Posted: January 29, 2012 at 12:39 AM / IP Logged
Posted: January 30, 2012 at 1:35 AM / IP Logged
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Thou art cruel!
But no, I'm merely responding. Earlier I was thinking some high-impedance voltage may be being measured (ie, the 9V) - not that charging system variation has been discounted - but I thought KIS. Or, not yet... at least.
And using a relay-coil's pull-in and drop-out behavior as a voltage window sensor has worked often for many. (IE - drop the voltage. A resistor may be ok, but diodes have a essentially a constant voltage drop that is more current independent.)
In some cases that easier than diatribe.
Besides, if the 9V output becomes a "normal" 0 (off or low or 0V), then just remove the add-ons above.
