2010 dodge dakota
tnecius
Member - Posts: 8
Posted: January 28, 2012 at 8:56 PM / IP Logged
Hi All,
I am looking for a little help on an alarm install with remote start... I have a 2010 Dodge Dakota Big horn crew cab truck... and am looking for any information that will assist with the install of a Clarion/Ungo/DEI sr5000. Specifically the wiring to the vehicle... This truck does not have the chip in the fob, so, my other question is does it need any bypass or otherwise any type modules? I know with the on board computer a lot of things are done by way of resisters and finding anyone that has done this type of vehicle would be great to here from.
- R
San Diego
Twelvoltz
Platinum - Posts: 2,384
Posted: January 28, 2012 at 9:37 PM / IP Logged
Audiovox lists:
#520456: 2010 DODGE DAKOTA 4DR TRUCK WITH 3.7L ENGINE AND STANDARD AUDIO SYSTEM
Audio/Mobile Video
     WIRE COLOR POLARITY LOCATION
Battery RED / BLACK (+) RADIO HARNESS
Accesory WHITE/ ORANGE & WHITE (DATA) RADIO HARNESS
THIS VEHICLE USES THE CAN DATA NETWORK FOR ACCESSORY TURN ON
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) GRAY/VIOLET
LF Speaker (-) GRAY / YELLOW
RF Speaker (+) DARK GREEN/ VIOLET
RF Speaker (-) DARK GREEN/ YELLOW
LR Speaker (+) GRAY/LIGHT GREEN
LR Speaker (-) GRAY/DARK GREEN
RR Speaker (+) DARK GREEN/ LIGHT GREEN
RR Speaker (-) LIGHT GREEN/ GRAY
Amp Location SEE ALPINE AUDIO TRIM FOR AMPLIFIER INFORMATION
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Battery LIGHT BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 PINK/GRAY (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW/GRAY (+) AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
NOT FOR REMOTE START,
All Door Trigger YELLOW/OREANGE (+) IN HARNESS AT VEHICLE GAUGE CLUSTER
TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
Domelight Super YELLOW/ORANGE (+) IN HARNESS AT VEHICLE GAUGE CLUSTER
LF Latch VIOLET (-) IN HARNESS AT VEHICLE GAUGE CLUSTER
RF Latch VIOLET/WHITE (-) IN HARNESS AT VEHICLE GAUGE CLUSTER
LR Latch VIOLET/GRAY (-) IN HARNESS AT VEHICLE GAUGE CLUSTER
RR Latch VIOLET / YELLOW (-) IN HARNESS AT VEHICLE GAUGE CLUSTER
Hood Trigger VIOLET/LIGHT BLUE (-) AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
Alarm Disarm
CAN ONLY BE DISARMED BY OEM KEYLESS REMOTE CONTROL.
Parking Lights PINK/RED (-) AT VEHICLE LIGHT SWITCH HARNESS
USE A 1.1K OHM RESISTOR FOR PARKING LIGHTS, MUST ISOLATE FROM SWITCH WITH A RELAY
Convenience
Headlights-Lo PINK/RED (-) AT VEHICLE LIGHT SWITCH HARNESS
USE A 660 OHM RESISTOR, MUST ISOLATE FROM THE SWITCH WITH A RELAY
LF Pk Lt Bulb PINK/RED (+) AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
RF Pk Lt Bulb WHITE/ ORANGE (+) AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
LR Pk Lt Bulb PINK/RED (+) AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
RR Pk Lt Bulb WHITE/ ORANGE (+) AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
All Hazrd Lights WHITE/ ORANGE (-) AT VEHICLE HAZARD SWITCH
USE A 115 OHM RESISTOR, MUST ISOLATE FROM THE SWITCH WITH A RELAY
Wipers-Lo BROWN / WHITE (+) AT WIPER MOTOR
Wipers-Hi BROWN / ORANGE (+) AT WIPER MOTOR
Parking Brake DARK GREEN / WHITE (-) IN HARNESS AT VEHICLE GAUGE CLUSTER
ALSO AT VEHICLE PARKING BRAKE SWITCH
Remote Start
Accessory 1 VIOLET/BROWN (-) IGNITION SWITCH HARNESS
USE A 560 OHM RESISTOR FOR ACCESSORY, SAME WIRE AS STARTER 2, **
Starter 2 VIOLET/BROWN (-) IGNITION SWITCH HARNESS
USE A 180 OUM RESISTOR FOR STARTER 2, SAME WIRE AS ACCESSORY, *
Anti-Theft Type DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense VIOLET/BROWN (-) IGNITION SWITCH HARNESS
USE AN 8.5K OHM RESISTOR FOR KEYSENSE, SAME WIRE AS STARTER 2 AND ACCESSORY, ***SEE DOCUMETS
Speed Sense YELLOW/PINK (AC) AT PCM MODULE UNDER HOOD ON PASSENGER FENDER
MAY BE YELLOW/BLACK ON SOME MODELS
Brake Lights WHITE/ LIGHT BLUE (+) AT SWITCH ABOVE PEDAL
Reverse Lights WHITE/ LIGHT GREEN (+) AT IPM MODULE UNDER HOOD ON DRIVER SIDE FENDER
Horn DARK GREEN/ VIOLET (-) IN HARNESS AT STEERING COLUMN
Modules
     WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock VIOLET/DARK GREEN (-) IN HARNESS FROM DOOR HIGH IN DRIVERS KICKPANEL
UNLOCK IS THROUGH A 100 OHM RESISTOR
PowerLock VIOLET/DARK GREEN (-) IN HARNESS FROM DOOR HIGH IN DRIVERS KICKPANEL
LOCK IS THROUGH A 330 OHM RESISTOR
LF Window Up ORANGE / LIGHT GREEN (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn ORANGE / WHITE (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up ORANGE / TAN (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn ORANGE / GRAY (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up ORANGE / BLACK (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn ORANGE / RED (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up TAN / YELLOW (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn ORANGE / DARK BLUE (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
A 2010 without a transponder? Are you sure about that? How did you determine it does not have a chip in it? I can't recall one that new that didn't have a transponder. If you post a picture of the circuit board in the remote it would allow us to determine if it does or does not have that chip.
I would suggest picking up a ADS-AL-CA ( www.idatalink.com) flashed for your vehicle. It will do door locks, alarm, handle the MUX circuit, transponder bypass, etc.
tnecius
Member - Posts: 8
Posted: January 28, 2012 at 9:49 PM / IP Logged
Thanks for the response! I was first confused, and then purchased a key blank from a random key shop... I then was able to start the vehicle without the original key present or in close proximity.... I called the dealer, and was told the my vehicle did not have the transponder key when they searched for the part ($50 as opposed to $180 - $200). It was not scientific, but, it made sense...
Again, Thanks for the quick response.
- R
S.D.
offroadzj
Gold - Posts: 2,043
Posted: January 28, 2012 at 10:00 PM / IP Logged
If you don't mind paying a little extra for the bypass, pick up an EVO-CHR with the T-Harness (I believe its the CHR2 but check first). It will turn your install into about a 10 minute install. A few quick connections between the remote start and the bypass, then 12v to the battery, ground to the chassis, and a quick parking light connection and you are done. I did a 2010 caliber in about 30 minutes including prep, disassembly, install, and reassembly. If you haven't picked up the starter yet you can get the all in one Fortin bypass that will eliminate the need for the remote starter. You have the option of running it off the factory remote as it comes (lock 3 times) or you can add a compustar antenna/remote kit and extend the range / options.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
tnecius
Member - Posts: 8
Posted: January 28, 2012 at 10:14 PM / IP Logged
Thanks for the reply! These have been helpful responses... These units, are most mail ordered, or could you pick one up at say Fry's Electronics, Best Buy, Al & Ed's?? (Probably too much money)... I will check it out on the web and probably order one there.
Thanks!
-R
S.D.
tnecius
Member - Posts: 8
Posted: January 29, 2012 at 6:58 AM / IP Logged
After a little guidance from here, and a little research... I have decided on the XpressKit DB-ALL and XKLoader2. I think with these two items, I can complete my install and move forward to other projects (i.e. Second Battery, and Accessories).
Thanks to all who responded, and I hope these few entries helps someone else in need.
- R
S.D.
Thursday, October 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
