1975 Chevrolet Caprice Wiring?
hemiboy29
Member - Posts: 22
Posted: February 13, 2012 at 9:01 PM / IP Logged
L&G's,
  Good evening, i am looking for the wiring diagram for a 1975 chevrolet caprice if you can help me with that i will be greatly appreciated!
Platinum - Posts: 13,726
Posted: February 13, 2012 at 9:15 PM / IP Logged
For the entire vehicle?
hemiboy29
Member - Posts: 22
Posted: February 15, 2012 at 9:54 PM / IP Logged
yes please
Posted: February 15, 2012 at 10:44 PM / IP Logged
What are you trying to do?
hemiboy29
Member - Posts: 22
Posted: February 16, 2012 at 5:24 PM / IP Logged
pretty much restoration fixing at the old broken wires and stuff and re-wiring a new engine can you help me out?
hemiboy29
Member - Posts: 22
Posted: February 16, 2012 at 7:43 PM / IP Logged
also having some issue where when the brake is pressed the front parking light go on so there must be a short or something connected wrong that i need to resolve because its driving me absolutely nuts
Ween
Platinum - Posts: 1,368
Posted: February 16, 2012 at 7:53 PM / IP Logged
check for bad grounds on your taillights.
mark
flobee4
Silver - Posts: 585
Posted: February 16, 2012 at 8:01 PM / IP Logged
Also check the rear light, if you have a "single" filament bulb in a "dual" filament Socket. That would cause a backfeed when you hit the brakes to the parking lights.
hemiboy29
Member - Posts: 22
Posted: February 16, 2012 at 8:32 PM / IP Logged
Perfect thanks for your help fellas i will check that... hoping someone can help me with the wiring diagram for this vehicle
oldspark
Gold - Posts: 4,913
Posted: February 17, 2012 at 12:53 AM / IP Logged
x2 on the check grounds.
If it's a dual filament stop/tail light and the ground breaks, the tail lights ground the brake light, hence lighting other park lights.
