99 civic 50.5 unlock issue
redsidriver
Posted: February 21, 2012 at 1:34 AM / IP Logged
having issues getting the alarm to unlock when disarming the alarm . the doors lock and everything else works perfect have had this issue for a while but i finally want to take care of this . I am confident i have the correct wires on both alarm and on the car . maybe im missing something but i just dont know .
offroadzj
Gold - Posts: 2,043
Posted: February 21, 2012 at 5:53 AM / IP Logged
Locks:
Power Lock GREEN / WHITE   - keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock GREEN/ orange   - keyless entry module
Are those the wires you connected to for your lock/unlock? Did they test correctly? Are you getting a good ground signal out of the alarm?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
tedmond
Gold - Posts: 4,610
Posted: February 21, 2012 at 7:42 AM / IP Logged
select civics never had a keyless module at the kick panel, however the vehicle still had keyless as it was in a different location. if you dont have this module in the kick, you will see a green connector at the steering column. that green connector is taped to a black harness with a small blue tape indicator.
if all else fails, grab the GREEN/ orange (-) unlock at the harness going into the door.
Ted
Compustar Expert
ropuma
Copper - Posts: 102
Posted: February 21, 2012 at 9:13 AM / IP Logged
Lock- green&white
unlock-green$orange kick panel module.
Or get this wires at the keyless entry module behind the radio green plug,this keyless entry module is part of the radio.
redsidriver
Posted: February 21, 2012 at 3:06 PM / IP Logged
yes those are the colored wires im using . i do have the keyless entry module and the factory alarm plug does not have those colored wires on it . one thing i do need to mention is that i dont have the oem lock and unlock switch on the driver door hooked up . i dont know if that has anything to do with it or not . i think the grounds are good but i did combine them all and attached to the same spot i dont know if that would affect it working or not .
