gm lan in dash
pts760
Copper - Posts: 403
Posted: February 22, 2012 at 1:58 AM / IP Logged
I've never done this but have seen this. I know they make a alternative harness for GM Class II Data Bus radio that work fine but lose RAP and warning chimes but Do they make one for the LAN system and is it possible for GM vehicles with the LAN system. I'm saying if a customer is willing to lose their onstar and warning chimes. Has anyone done this and have they had any drawbacks with it?
I drink current, eat ohms, and bleed voltage
pts760
Copper - Posts: 403
Posted: February 25, 2012 at 11:48 PM / IP Logged
No response? Seriously? This isn't a technical question. please help
Platinum - Posts: 13,726
Posted: February 26, 2012 at 8:33 AM / IP Logged
I would be able to help you if I knew the Make Model and Year of the car in question.
99-06 metra 70-2--3
07- Current    Metra 70-2105
As long as the customer knows they will lose On-Star, Warning Chimes and Retained Acc, no drawbacks at all.
soundnsecurity
Gold - Posts: 2,720
Posted: February 26, 2012 at 11:35 PM / IP Logged
ive had strange experiences when didnt use the lan harness. over time it seems to cause problems with the cars computer mainly i think because there may be some kind of data feedback between the factory radio and the BCM that gets lost when you replace the stock unit with a regular plug. you can get a harness that just retains the data connection and chime functions for maybe $100 and it saves you the hassle of having to run your own accessory wire to turn the aftermarket radio on.
pts760
Copper - Posts: 403
Posted: February 27, 2012 at 1:10 PM / IP Logged
Do you happen to know the model number of that part? I'm interested in doing further research on that part.
pts760
Copper - Posts: 403
Posted: February 27, 2012 at 1:12 PM / IP Logged
99-06 metra 70-2--3
I wasn't aware that any GM vehicle 99-06 ran on a LAN system. Anyway, thanks for the reply im gonna check out the 70-2105.
soundnsecurity
Gold - Posts: 2,720
Posted: February 27, 2012 at 1:47 PM / IP Logged
the chime data plug is either c2r-gm29 or c2r-gm11. which one depends on the make model and year of your car. they are made by PAC. let me know what car you have and ill tell you which one you need
Posted: February 27, 2012 at 9:23 PM / IP Logged
http://www.metraonline.com/part/LC-GMRC-LAN-01  Sells for 70 dollars.
We have used the 2105 on many occasions, I have never seen a problem using it.
pts760
Copper - Posts: 403
Posted: February 28, 2012 at 12:47 AM / IP Logged
That info is very helpful. I will keep that in mind on the next install.
