viper 4704v lc3
nbboy7
Member - Posts: 19
Posted: March 12, 2012 at 10:39 PM / IP Logged
Hello I need help wiring the ignition wire for the remote start. It's going in my 99 Honda civic.
Here are the wires from the alarm.
Pink: (+) Ignition 1 Input/Output
RED / White: (+) 12VDC Constant Input for Ignition 2 and Flex Replays
Orange: (+) Accessory Output
Violet: (+) Starter Output
Red: (+) 12VDC Constant Input for Ignition 1 Relay
Pink/White: (+) Ignition 2 / Flex Relay Output
Pink/Black: (+) Flex Relay Input 87A Key Side (If required) of Flex Relay
RED / Black: (+) 12VDC Constant Input for ACC and Starter Relays
Here the wires to the civic
12V CONSTANT WIRE WHITE Ignition harness
12V IGNITION WIRE BLACK / YELLOW Ignition harness
SECOND IGNITION WIRE YELLOW Ignition harness
STARTER WIRE BLACK/ WHITE Ignition harness
ACCESSORY WIRE WHITE/ BLACK Ignition harness
Posted: March 13, 2012 at 1:20 PM / IP Logged
Red, RED / white and RED / black to white.
Pink to BLACK / YELLOW.
Violet to BLACK/ white.
Pink/white to yellow, you can also program this as ACC1 and make the other ACC ACC2.
Orange to WHITE/ black
What's the problem?
Wednesday, August 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
