10 honda accord
4trxrd
Posted: March 30, 2012 at 12:29 AM / IP Logged
I just installed a remote start in a 2010 honda accord using a avital 4103 and a idata bypass it all worked good but I can"t lock and unlock the doors when the cars running  I ran the door lock though the bypass module? any help would be great thanks
flobee4
Silver - Posts: 585
Posted: March 30, 2012 at 8:54 AM / IP Logged
on the idatalink make sure the BLACK/ white wire marked as starter and the Pink wire marked as ignition. they need to be tapped into the starter and ignition wire respectively. you can tap in at the car's ignition harness or the remote starters ignition harness.
Also just to make sure you are aware, the Honda's remote will never operate locks while running, you have to use the 4103 remote to unlock the door.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
