two triggers on one relay
bennybongo87
Member - Posts: 10
Posted: April 17, 2012 at 3:38 PM / IP Logged
Hi there. Just wondering if anyone could help me out. I currently have two relays set up in my car doing different things. Relay one powers footwell lights in car triggered by dome light on roof. Relay 2 powers fog lights triggered by fog position on headlight switch. What I was wondering now is can I use the output of relay one to also trigger relay two so that when I unlock my car via remote and dome light comes on it will trigger my fogs to come on?
bennybongo87
Member - Posts: 10
Posted: April 18, 2012 at 4:08 AM / IP Logged
Anyone got any info on this, it would be greatly appreciated..
KPierson
Platinum - Posts: 3,527
Posted: April 18, 2012 at 2:21 PM / IP Logged
It depends on many different factors. I will make some assumptions here.....
I assume that your fog light switch is a (+) and that relay 2's coil is permanently grounded.
I assume your footwell lighting has the (+) side switched meaning it is permanently grounded.
If these assumptions are correct you can take the (+) voltage out of the contacts of Relay 1 and connect it to the coil wire on Relay 2 THROUGH a 1A diode with the stripe closer to the relay. You will need to remove the fog light trigger and run it through a 1A diode as well, again stripe facing relay.
The diodes will prevent backfeeding from one source to the other.
Kevin Pierson
bennybongo87
Member - Posts: 10
Posted: April 18, 2012 at 2:32 PM / IP Logged
Thanks for your reply Kevin. Both your assumptions are correct to my knowledge. So your saying both wires that I'm planning to use for triggers of relay two go into it through two seperate diodes? Where would I get these diodes?
KPierson
Posted: April 18, 2012 at 7:54 PM / IP Logged
Yes, you will need (2) 1A diodes. You can get them at an electronics store like a Radio Shack (or whatever you UK equivalent is). The part number should be something like 1n4001 from memory.
Kevin Pierson
Platinum - Posts: 13,726
Posted: April 18, 2012 at 10:04 PM / IP Logged
1n400X  X = any number from and including 1 and 7.
bennybongo87
Member - Posts: 10
Posted: April 19, 2012 at 4:15 PM / IP Logged
ok i think i got it now. just for talking sakes, what would happen if relay 2 trigger sent a pulse up to the + output of relay 1? (if i didnt use diodes)
KPierson
Posted: April 20, 2012 at 12:34 PM / IP Logged
Without the diodes installed every time you turn on the fog lights it will send power to your footwell lights.
Kevin Pierson
bennybongo87
Member - Posts: 10
Posted: April 21, 2012 at 12:29 PM / IP Logged
Hi. I just got my footwell lights installed using the reverse polarity method. The footwell lights work well but when they go off there is a loud buzz from the relay. The dome lights have switched negative and that's why I used the reverse polarity method to power footwell lights. Is there any way to stoop buzzing relay?
Posted: April 21, 2012 at 3:52 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=114184&KW=bellsracer
