mids and tweets into 4ch amp info wtd
shabbadabba
Member - Posts: 11
Posted: April 21, 2012 at 2:54 AM / IP Logged
hiya guys
i need a little info please
my head units an alpine cda 9835
mids are 6.5" dls ps6
tweets are a decent quality
i want to run the mids and tweets off a 4 channel amp
mids off 1 channell,tweets off another
and a sub off another amp
anyone know how to change the settings for my tweeters on the hu ?
ive been told i need to bring it down to about 4khz
all advice welcome
DYohn
Platinum - Posts: 10,741
Posted: April 21, 2012 at 9:06 AM / IP Logged
What are you using for crossovers?
soundnsecurity
Gold - Posts: 2,720
Posted: April 21, 2012 at 9:35 AM / IP Logged
i run my front components off of an alpine 4 channel. the tweeters take up 2 channels and the mids use the other two. i have to run the signal through a 3 way electronic crossover because i am not using the crossovers than came with the set of components. is this something you are trying to do?
shabbadabba
Member - Posts: 11
Posted: April 22, 2012 at 2:25 AM / IP Logged
i have no crossovers
i wish to use setup as above,2 channells for tweeters,and 2 for the mids,all setup on the hu
DYohn
Posted: April 22, 2012 at 9:31 AM / IP Logged
You must use crossovers.  Fortunately your CDA-9835 has crossovers built into it.  See page 15-16 of your owner's manual.  The trick will be knowing what pass bands to set for your woofer and tweeter.  DLS uses a 4KHz crossover in their component set using that woofer, so you are likely safe setting it as the mid band (rear outs) with a high pass of 80Hz and a low pass of 4000Hz, and using your tweeters as the high band (front outs) with a high pass of 4000Hz and hope the ones you've chosen can handle that.  You'll need to use the gains on the amp to balance the levels.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
