false alarm non stop
Chaser
Member - Posts: 31
Posted: May 04, 2003 at 6:25 PM / IP Logged
My alarm is falsing every half hour or so.  It either shows that a door is open or the trunk.  It is the two way Vadar alarm. I have put diodes on both door trigers and on the trunk trigger as well.  Anyone know why its doing so and what I can do to fix it.
draasch
Gold - Posts: 2,172
Posted: May 04, 2003 at 8:54 PM / IP Logged
what is the yr, make, and model of car....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: May 04, 2003 at 10:10 PM / IP Logged
You will need to use a relay as well as diodes to isolate the trigger wires from each other.
Chaser
Member - Posts: 31
Posted: May 13, 2003 at 2:57 PM / IP Logged
2002 mustang
draasch
Gold - Posts: 2,172
Posted: May 13, 2003 at 8:33 PM / IP Logged
you can try this too....
***Dome Light:Ford's G.E.M. Will Drop A Low Signal Across The Dome Light And In Most Cases Cause A False Trigger. To Eliminate This Cut the Door Pin Trigger Wires At The G.E.M. And Insert A One-Amp Diode With Band Side Faceing Doors.Make Your Isolated Connection On The Door Pin Side. The GEM (Generic Electronic Module) is to the left of the radio
Good Luck
David
Ace Security
813-376-9778
Tampa
Chaser
Member - Posts: 31
Posted: May 15, 2003 at 3:48 PM / IP Logged
I have already installed diodes on both door trigers and on the trunk trigger.  When the alarm goes off it shows as if the trunk was open, but it is not.  I asummed that the diodes are ok since they were new but i am going to check just to make shure.  IF ANYONE HAS ANY SUGGESTIONS PLEASE LET ME KNOW
THANKS
eckoblaze72
Member - Posts: 22
Posted: May 17, 2003 at 10:39 AM / IP Logged
i had something like that happen to my alarm to but mine had water dripping into it from off the serin wire.
auex
Platinum - Posts: 5,041
Posted: May 17, 2003 at 2:07 PM / IP Logged
What input are you connecting the trunk pin to( door or instant negative trigger)? Also as far as diode isolating the triggers, you need two diodes per trigger, one inline with the factory wire isolating the switch from the computer and one isolating the triggers from each other to the alarm.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Jamieh560
Posted: May 18, 2003 at 8:59 PM / IP Logged
I got the same problem with my 97 explorer, what color are the wire the u cut at the GEM module too add dioides. THANKS
Chaser
Member - Posts: 31
Posted: May 20, 2003 at 3:45 PM / IP Logged
The alarm i got has an input for the two door triggers and another for trunk/hood.  Just a stupid question but why would you need to isolate the two door trigers from each other?
