2011 subaru forester wiring diagram
pedroxrlima
Posted: May 14, 2012 at 5:44 PM / IP Logged
Hello,
does anyone have the wiring diagram of the 2011 subaru forester?
I need specially the tach wire. What is the color? and where is located?
I am installing a remote start engine.
Thanks in advance.
chev104275
Gold - Posts: 1,436
Posted: May 14, 2012 at 5:59 PM / IP Logged
FORESTER 2009 -2012
KEY T-HARNESS IMMOBILIZER
N/A N/A SUBARU'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE (+) 50 AMP @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 3
STARTER WHITE/ BLACK (+) @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 2
STARTER 2 WHITE/ RED (+) @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 6
IGNITION 1 GREEN (+) @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 1
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 BLUE (+) @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 4
ACCESSORY /HEATER BLOWER 2 YELLOW (+) @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 5
KEYSENSE N/A
PARKING LIGHTS ( - ) BLACK/ WHITE (-) @ HEADLIGHT SWITCH or BIU, (WHITE, 26-PIN PLUG), PIN 11, NOTE #2
PARKING LIGHTS ( + ) PINK (+) in DRIVERS KICK PANEL, Harness to REAR of Vehicle
POWER LOCK LT. GREEN (-), TYPE B in DRIVERS KICK PANEL or BIU, (WHITE, 35-PIN PLUG), PIN 15, NOTE #2
POWER UNLOCK BLUE/BLACK (-), TYPE B in DRIVERS KICK PANEL or BIU, (WHITE, 35-PIN PLUG), PIN 29, NOTE #2
LOCK MOTOR WIRE LT. GREEN/ YELLOW (+) in DRIVERS KICK PANEL or BIU, (WHITE, 35-PIN PLUG), PIN 7, NOTE #2
DOOR TRIGGER ORANGE / WHITE (-) in DRIVERS KICK PANEL or BIU, (WHITE, 35-PIN PLUG), PIN 19, NOTE #2
DOMELIGHT SUPERVISION BLACK/ RED (-) in PASSENGER A Pillar or BIU, (WHITE, 30-PIN PLUG), PIN 5, NOTE #2
TRUNK RELEASE GREEN/ RED (-), NOTE #3 in PASSENGER KICK PANEL or BIU, (WHITE, 28-PIN PLUG), PIN 24, NOTE #2
SLIDING POWER DOOR N/A
HORN BROWN to RED / WHITE (-) @ HORN SWITCH or BIU, (WHITE, 30-PIN PLUG), PIN 29, NOTE #2
TACH GRAY/RED, (AC) @ INSTRUMENT CLUSTER, (WHITE, 40-PIN PLUG), PIN 32
WAIT TO START LIGHT N/A
BRAKE BROWN / WHITE to LT. GREEN (+) @ BRAKE PEDAL SWITCH or BIU, (WHITE, 26-PIN PLUG), PIN 2
FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY!!
ANTI-THEFT SUBARU'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: SUBARU'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 Bypass Module (for REMOTE STARTING ONLY!)
NOTE #2: the BIU, (Body Integrated Unit) is located under the DRIVERS DASH, and to the RIGHT of the STEERING COLUMN.
NOTE #3: TEST this wire while Opening the LIFTGATE from the Handle on the REAR of the
Wednesday, September 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
