bose pre amp high level outputs?
cizzo19
Posted: May 24, 2012 at 12:23 PM / IP Logged
Hi, i have a 2007 cadillac and it has the bose amplifier hooked up to a stock 8" sub in the rear deck. I just bought JL Audio PWM112-JXWXv2 and it comes with a jl amp mounted on the back and i will be using my stock head unit...so my questions are 1. does anyone know what color the remote wire is on the stock amp? 2.should i use the stock power and ground from the stock amp or should i run a new power and ground? 3.Where can i find out what wires to the bose amp are power,ground,remote,and speakers? Thanks for reading and any info.
Platinum - Posts: 13,725
Posted: May 24, 2012 at 1:55 PM / IP Logged
Run your own power and ground. There may not be a conventional remote turn on for that amp. Some of them use data from the BCM to turn on.
cizzo19
Posted: May 24, 2012 at 2:02 PM / IP Logged
Thanks i will run the power and ground.What do you suggest i do for the remote wire?
Posted: May 24, 2012 at 4:49 PM / IP Logged
Pac-Audio.com soem-t. It is a line out converter that has audio sensing to provide a remote output when it senses audio.
cizzo19
Posted: May 24, 2012 at 5:20 PM / IP Logged
Thanks for all your input! I will pic one of those LOC up.
