aue 70 fuse
jbano13
Posted: June 03, 2012 at 11:21 AM / IP Logged
I have an inline fuse set up before a power inverter in a bus, the fuse blew and I am trying to replace it. I took out the fuse and it is labeled AUE 70. I tried going to all my local auto stores and electronics stores but had no luck. It is a 12v system. The fuse is about the same size as an AGU fuse but the filament inside is much smaller. Does anyone know where I can find a replacement fuse or maybe an equivalent AGU fuse?
Platinum - Posts: 13,725
Posted: June 03, 2012 at 1:54 PM / IP Logged
AUE and AGU appear to be the same.   Do a search for aue fuse.
jbano13
Posted: June 04, 2012 at 11:07 AM / IP Logged
I have searched everywhere locally and online. They seem to be the same size but the filaments inside are much smaller on AUE fuses. I have found some information but haven't found anywhere to buy it.
tommy...
Gold - Posts: 1,901
Posted: June 04, 2012 at 3:16 PM / IP Logged
If it is rated the same, then it shouldn't matter. AFAIK, and AGU/AUE type fuse is only good , up to 60 Amps, anyway.(Because of their connection points inside the gold cap). A 70 Amp AGU fuse SHOULD work the same as a 70 Amp AUE fuse. $2 or so , locally...
M.E.C.P & First-Class
Posted: June 05, 2012 at 9:32 AM / IP Logged
Simple rule, if it fits and has the same rating.....
Friday, January 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
