08 tundra factory back up camera
nuggy26
Posted: July 13, 2012 at 1:03 PM / IP Logged
Hey guys just trying to hook factory back up camera to aftermarket double din. Do anyone have any suggestions?
nuggy
Platinum - Posts: 13,725
Posted: July 13, 2012 at 7:56 PM / IP Logged
With the OEM system, where did the camera display?
Mike M2
Platinum - Posts: 2,652
Posted: July 13, 2012 at 10:08 PM / IP Logged
The camera shows in the mirror if there's no factory nav. On this truck i found it easiest to just go to the plug on the mirror for signal. Further up the plug 4 wires go into a coax cable feeding the camera. 2 are signal and 2 are power for the camera, don't remember which is what but it's easy to figure out. It is a 7 volt camera so use your DVM to determine which are right.
If it's a nav truck your SOL because the nav supplies the power for the camera.
Mike M2
Tech Manager
CS Dealer Services
nuggy26
Posted: July 14, 2012 at 1:33 AM / IP Logged
Its a small flip down screen that hangs kinda buy the rear view mirror
nuggy
Posted: July 14, 2012 at 1:55 PM / IP Logged
Either way, nav unit or standalone monitor, you should be able to interface it with an aftermarket deck.
How many wires are there on the harness that supplies the monitor?
Does the monitor power up when you put the vehicle in reverse? or is there a separate power button?
nuggy26
Posted: July 14, 2012 at 5:29 PM / IP Logged
9 wires and powers up when in reverse. No seperate power button
nuggy
Mike M2
Posted: July 14, 2012 at 8:15 PM / IP Logged
The flip down was rare, but still a 7 volt camera. Back then Fugitsu Ten made all Toyotas stuff and all the cameras were 7 volt buy them. Have you tried looking further up the harness for a sheilded harness inside the monitor harness?
Mike M2
Tech Manager
CS Dealer Services
nuggy26
Posted: July 14, 2012 at 8:35 PM / IP Logged
I have pics but how do I post them
nuggy
Posted: July 14, 2012 at 9:36 PM / IP Logged
08 tundra factory back up camera -- posted image.
Posted: July 14, 2012 at 9:37 PM / IP Logged
The previous image is exactly opposite of what you are trying to do.  The wire colors may help you with your project.
