relay diagram
elmook
Posted: July 23, 2012 at 1:03 PM / IP Logged
I'm needing a relay diagram for a 2000 s-type jaguar 3.0 liter. bought car without manual. Cooler fan's not working.has numbers in diagram,but don't show which relay is for the cooler fan.Please help!
m.e.
tommy...
Gold - Posts: 1,901
Posted: July 23, 2012 at 3:42 PM / IP Logged
http://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-15/handbook-download-10578/
M.E.C.P & First-Class
elmook
Posted: July 23, 2012 at 9:18 PM / IP Logged
Appreciate the reply,but mines is a V-6.The manual you suggested downloading is for a V-8.They wouldn't be the same,would they?
m.e.
Platinum - Posts: 13,724
Posted: July 24, 2012 at 8:13 AM / IP Logged
They should be similar enough to help you.
elmook
Posted: July 24, 2012 at 12:12 PM / IP Logged
Ok thanks,appreciate it
m.e.
Posted: July 24, 2012 at 5:21 PM / IP Logged
Or access Lincoln Town Car of the same year, same car.
The cooling system will be identical.
Relay 7 in the engine bay fuse and relay box, wiring as follows.
85 as terminal 2, BROWN / black.
86 as terminal 3 and 30 as terminal 1 both RED / green.
87 as terminal 5 (output)RED / black.
You can work out which patterns with a DMM, set to continuity.
86 and 30 are common.
85 will go to ground when engine on and AC engaged.
That leaves you 87 by default.
My guess is that you're looking at a standard Bosch/Tycho 4 pin cube relay available any where.
supply 12volts to86 and ground 85, relay should click and 87 and 30 should then get continuity.
By the way, it's rarely the relay that fails, I'd look at the 10 amp control fuse or the signal at 85 from the AC ECU.
The good bit is that it's probably available as a Lincoln part for a lot less.
Posted: July 24, 2012 at 5:23 PM / IP Logged
Sorry got the wiring info from an English equivalent to Mitchells, it's for the English version but apparently V6 and V8 were the same.
elmook
Posted: July 24, 2012 at 6:03 PM / IP Logged
I appreciate you sir. Thanks.
m.e.
