hair trick advice
fighterboy124
Member - Posts: 29
Posted: August 24, 2012 at 10:21 PM / IP Logged
i have 4 10" JL Audio 10WXV2-4, 1 treo rsx1600, 1 xs power D2400 battery and 1 AudioControl Epic-160 i am puting this system in the back of my 04 trailblazer. my question is how can i squeeze every inch of juice out this system and to make it do hair trick now i know this is impossible with the components i have so can somebody tell me how to make this system BEAT !!!!!
Nick Miller
tommy...
Gold - Posts: 1,901
Posted: August 25, 2012 at 8:53 AM / IP Logged
Which alternator did you buy...?
http://www.ohiogen.com/html/catalog.html
M.E.C.P & First-Class
soundnsecurity
Gold - Posts: 2,720
Posted: August 25, 2012 at 9:13 AM / IP Logged
use sound dampening material to make sure the back of your car is sealed as good as possible so that the air has nowhere to go but to the front.
new alternator and big 3 upgrade.
if you arent happy with the sound then if you have the resources try building different boxes with different airspaces and tuning frequencies . sometimes this can be a waste of time but it might surprise you how much you can gain just with a different box design.
auto enhancers
Copper - Posts: 203
Posted: August 25, 2012 at 4:13 PM / IP Logged
Good luck with the equipment. It is not an easy task. You will need a box that is going to move a lot of air. Realistically if you are putting them in the rear cargo area I would guess it is not going to happen. If you build a wall you may have a shot but still not likley.
It requires quit a bit to achieve something like that.
