does my alarm have onboard lock relays?
breaker1369
Member - Posts: 27
Posted: October 27, 2012 at 7:44 AM / IP Logged
ive searched everywhere and have a question
i have a clifford matrix I alarm system and wondered if it had onboard lock relays see the thing is i have an s10 pickup with no factory door locks period and noticed that at one time 2 wire door actuators were installed and want to connect them directly to the alarm as arm/disarm without switches do i still need to wire up relays or can i wire the actuators directly to the blue and green wires frm the 2 pin harness on the brain it notes that the blue wire is (-)unlock (+) lock and green wire is (-)lock (+) unlock
racerjames76
Silver - Posts: 581
Posted: October 27, 2012 at 8:05 AM / IP Logged
If you read further in the description I am sure it states that is a low current circuit. Are the wires pretty small in thickness? You need a circuit that can handle 12-15 amps of current for actuators (up to 4). Play it safe put the relays in properly and nothing will get damaged that way. Relays are cheaper than a new brain unit! does my alarm have onboard lock relays? -- posted image.
To master and control electricity is perfection. *evil laugh*
Posted: October 27, 2012 at 10:25 AM / IP Logged
If it has two wires no, if 6 purple and PURPLE / black, BROWN / black, WHITE/ black blue/black and GREEN/ black then yes.
breaker1369
Member - Posts: 27
Posted: October 27, 2012 at 5:48 PM / IP Logged
thanks got it all hooked up and workin except one issue my interior lights stay on ill have the doors closed and the lights still remain on...any ideas?
Posted: October 27, 2012 at 6:26 PM / IP Logged
What car,make year and model?
Stay on for how long?
One minute?
breaker1369
Member - Posts: 27
Posted: October 27, 2012 at 6:32 PM / IP Logged
96 chevy s10 and they stay on all the time pulled the fuse out meanwhile
Wednesday, May 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
