2006 chevy radio
bhenry
Member - Posts: 14
Posted: November 25, 2012 at 4:34 PM / IP Logged
anybody know what wire i can tap to have an aftermarket radio shut off when door is opened rather than ignition being turned off?
soundnsecurity
Gold - Posts: 2,720
Posted: November 25, 2012 at 7:45 PM / IP Logged
as far as i know there is not wire you can tap to have this function. the factory radio is data controlled on/off and the only way you keep this function is with the adapter/integration harness.
you can use relays to add this function but you will need to have some knowledge of relay wiring and finding and testing wires in cars. i think the relay diagram is in the relay section of this website and is labeled "RAP shut down"
soundnsecurity
Gold - Posts: 2,720
Posted: November 25, 2012 at 7:49 PM / IP Logged
HERE is the page you use if your truck has a positive door trigger. there is a separate diagram if your truck has a negative door trigger.
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
