2012 ford ranger and turbo timer
t&t tech
Platinum - Posts: 2,608
Posted: December 12, 2012 at 7:22 AM / IP Logged
Installed a turbo timer on this van yesterday, everything's working, customer however wants to retain use of his factory keyless entry system, can anyone point me in the direction of the factory alarm module, or another possible solution. Also any info on the type of locking system on this van would be appreciated. It's a right hand drive 2012 ranger from Thailand.
shortcircuit161
Silver - Posts: 556
Posted: December 12, 2012 at 7:58 AM / IP Logged
Depending on the remote starter and bypass module used, you can try not connecting the keysense wire. Some vehicles prevent the factory keyless from working when it senses a key inserted in the ignition switch.
Also, if the Thailand version is similar to the US version, here is the wiring guide:
12volts      red (common 40A)      +      ignition switch, gray 13 pin plug, pin 2
Notes: If equipped, the Satellite Radio Receiver is behind the glove box.
Starter      blue/white      +      ignition switch, gray 13 pin plug, pin 5
Second Starter      N/A
Ignition      WHITE/ orange      +      ignition switch, gray 13 pin plug, pin 1
Second Ignition      N/A
Third Ignition      N/A
Accessory      BROWN / yellow      +      ignition switch, gray 13 pin plug, pin 8
Second Accessory      PURPLE / green      +      ignition switch, gray 13 pin plug, pin 3
Keysense      BLACK/ pink to blue/gray      -      ignition key switch, gray 10 pin plug, pin 10
Power Lock      gray / YELLOW      -      driver kick or SJB, black 32 pin plug (C), pin 5
Notes: The SJB (Smart Junction Box) is in the passenger kick.
Power Unlock      PURPLE / gray      -      driver kick or SJB, black 32 pin plug (C), pin 9
Lock Motor      gray/brown      5 wire      driver kick or SJB, gray 32 pin plug (B), pin 13
Unlock Motor      blue/green      5 wire      driver kick or SJB, black 32 pin plug (C), pin 12
Parking Lights+      PURPLE / white      +      headlight switch or SJB, black 22 pin plug (D), pin 5
Parking Lights-      N/A
Hazards      same as turn signals
Turn Signal(L)      PURPLE / white (F), purple (R)      +      turn signal switch, gray 12 pin plug, pins 10 and 9
Turn Signal(R)      gray / YELLOW (F), yellow (R)      +      turn signal switch, gray 12 pin plug, pins 7 and 8
Reverse Light      BROWN / yellow      +      frame harness to rear
Door Trigger      GREEN/ purple      -      driver kick or SJB, black 32 pin plug (C), pin 6
Dome Supervision      GREEN/ blue      +      SJB, black 32 pin plug (C), pin 8
This wire is also found in the rear half of the driver side running board harness.
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      N/A
Factory Alarm Disarm      N/A
Disarm No Unlock      N/A
Tachometer      grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh      ac      any fuel injector, black 2 pin plug, pin 1
Wait to start      N/A
Brake Wire      PURPLE / white      +      brake switch, tan 5 pin plug, pin 2
Parking Brake      gray/blue      -      parking brake switch, black 2 pin plug, pin 1
Horn Trigger      yellow/lt. green to yellow/red      -      horn switch or SJB, black 22 pin plug (D), pin 12
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Modules: Not Available
t&t tech
Posted: December 12, 2012 at 9:13 AM / IP Logged
No remote starter, just a turbo timer, no bypass or anything like that.
shortcircuit161
Silver - Posts: 556
Posted: December 12, 2012 at 9:35 AM / IP Logged
I apologize, I misunderstood and thought you meant a turbo timer as an addon to a remote starter. 2012 ford ranger and turbo timer -- posted image.
Posted: December 12, 2012 at 9:58 AM / IP Logged
Is there a listing for the Mazda version?
That's more likely to be similar to a Thailand version.
AFIK most smaller "Japanese" pick-ups are built in Thailand.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
