finished system,but need help
equalizir
Copper - Posts: 71
Posted: May 08, 2003 at 8:55 PM / IP Logged
hi all,i finally finished putting together my audio system.well i thought i did.i fired the car up after it had been sitting for almost two months now.it sounded pretty good.the only problem being i could only get the front speakers working.first ill list my setup,than list the problems/questions
clarion db625mp head unit
infinity kappa perfect 5.1 components
infinity 652i coaxials
audiocontrol 3xs crossover
zapco studio 100,150 and competition 2z50 amp
jl audio wo12" sub
  first off on my audiocontrol crossover since my front components came with passive crossovers i decided to use them instead of the 3xs.so i didnt use the front rca input on the 3xs.i only added the rear input to the crossover.should this matter?should i just run an rca line from the headunit to the front input of the crossover?the reason i ask this is because i have my studio 150 wired to my sub.the 150 powers up but im not getting anything from it.i have the sub output from my crossover to the sub amp.im wondering if the crossover isnt working because of what i mentioned earlier about not using the front rca inputs?thats one thing id like to know if i should do or just leave it alone.
  the other problem i have is my studio 100 amp is wired with my rear coaxial speakers.the amp doesnt even power up so i dont know what the deal with it is.does this mean the amp is dead or ...?is there a way i can test the amp without having it in the car?i just wanna make sure its working first.if not ill just get another one,but it cost me a bunch so id like to keep it if possible.
  i forgot to mention that i have the three amp turnons,crossover and two fans hooked up to a relay.i dont know if this matters but i thought id mention it.
  i know this is alot of information but if anyone can help me id really appreciate it.thanks alot
wvsquirrel
Gold - Posts: 1,237
Posted: May 08, 2003 at 10:09 PM / IP Logged
You can run seperate power and remote lines from the battery directly to the amp without having it in the car. If that works and the amp turns on, then you probably either overloaded the relay or wired it incorrectly. Your remote leads should be reading 12v at each amp.
Did you check your fuses? A blown fuse would also prevent the amp from turning on.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
equalizir
Copper - Posts: 71
Posted: May 08, 2003 at 10:44 PM / IP Logged
ok,ill check that out.i didnt know you could overload the relay.ill test the amp out tommorrow and see what i get.ill post back here.thanks squirrel
wvsquirrel
Gold - Posts: 1,237
Posted: May 08, 2003 at 11:17 PM / IP Logged
No prob. I'm not sure if "overloading the relay" was the correct termenology or not, I'm still learning more about using them. But I do know that if an amp isn't getting the full 12v from the remote then it will either not turn on, or do some other funny things. If it turns out to be the remote lead wasn't getting the correct voltage, then you can wire it into the acc of the ignition harness instead and the amp will turn on and off with the car (instead of the headunit), but will still work fine.
Squirrel
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
