2008 chrysler 300
ricardoboston
Copper - Posts: 268
Posted: January 17, 2013 at 5:57 PM / IP Logged
hello techs i need some info about this car ,with bypass will fit better,and any other info necessary please let me know , i also heard about chrysler harness, i do not know if it works.thanks
triniforever
Copper - Posts: 323
Posted: January 18, 2013 at 12:07 PM / IP Logged
First off this car is a nightmare lol. Just kidding for the bypass use idatalink ADS CA module flashed with CH4 firmware and this module will take care of everything through the vehicle canbus system only thing is you need a dealer to flash the module for you .
triniforever
soundnsecurity
Gold - Posts: 2,711
Posted: January 18, 2013 at 2:00 PM / IP Logged
some bypass modules have an extra accessory wire harness that is vehicle specific. its a plug and play harness which only leave a few other connections for you to make.
what exact alarm are you trying to install because it helps if you get a bypass that is compatible with the alarms data system to communicate between the alarm and the bypass.
ricardoboston
Copper - Posts: 268
Posted: January 18, 2013 at 10:11 PM / IP Logged
just a remote start, thanks
soundnsecurity
Gold - Posts: 2,711
Posted: January 19, 2013 at 3:45 PM / IP Logged
ricardoboston wrote:
JUST A REMOTE START, THANKS
what is the exact brand and model number of your remote starter?
ricardoboston
Copper - Posts: 268
Posted: January 22, 2013 at 7:45 PM / IP Logged
its a avital 4103lx
ricardoboston
Copper - Posts: 268
Posted: January 22, 2013 at 7:52 PM / IP Logged
theres any trick or anything that i should know before this installation start, i go to ads al ca should i do just R/S or R/S WITH LOCK AND UNLOCK?THANKS
