flashing fl can
mcove
Member - Posts: 6
Posted: January 26, 2013 at 4:43 PM / IP Logged
i installed a viper 5704 security and remote start and fl can on a 2007 jeep wrangler x manual trany. after all was installed and working fine i had a bad car battery and had to replace it.after it was installed i found that info was lost on the fl can and had to re flash. i buy a weblink updater and tried to flash the fl can off their web site but the computer would not recognize the idatalink updater.am i missing something?
soundnsecurity
Gold - Posts: 2,720
Posted: January 26, 2013 at 6:52 PM / IP Logged
the weblink updater doesnt work on google chrome. might not even work on firefox. i know that it is meant to use with internet explorer.
Platinum - Posts: 13,726
Posted: January 26, 2013 at 8:28 PM / IP Logged
It does NOT work on Firefox either. You have to use IE.
mcove
Member - Posts: 6
Posted: January 27, 2013 at 6:18 PM / IP Logged
when I plug in the usb on the idatalink to the computer it does not see it. i'm using IE vista,do i need to install a special driver?
mcove
Member - Posts: 6
Posted: January 27, 2013 at 6:32 PM / IP Logged
when i go into my computer to look at devices the idatalink does not show up. shouldn't the computer recognize it?
Posted: January 27, 2013 at 6:43 PM / IP Logged
I do not know, tomorrow I will plug ours in and see if it shows up on the computer. I do not think any drivers are needed. I will check with my installers, they may have had to install software.
Platinum - Posts: 7,828
Posted: January 27, 2013 at 8:07 PM / IP Logged
Look for a C:\SiLabs directory.  Think that is still part of the ADS USB cable support files.  Here is a link to the WebLink Updater 5.0 PlugIn download  :   http://www.idatalink.com/support#tab=_weblink-plugin         It will tell you if it is already loaded.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
