2008 mazda 3 remote start
donovansadv
Posted: February 19, 2013 at 4:00 PM / IP Logged
Anyone have the wiring color diagrams for a 2008 Mazda 3 manual (no alarm), need to install a remote starter and the keyless entry.
I am installing a crimestopper rs4-g3 remoter start using a PKALL By-Pass.
Thank you for your time in advance.
offroadzj
Gold - Posts: 2,043
Posted: February 19, 2013 at 4:42 PM / IP Logged
12volts      BLACK/ red (30A)      +      ignition switch
Notes: If equipped, the Sirius Satellite Radio is under the top center of the dash.
Starter      gray/black      +      ignition switch
Second Starter      N/A
Ignition      GREEN/ YELLOW      +      ignition switch
Second Ignition      N/A
Third Ignition      N/A
Accessory      pink / YELLOW      +      ignition switch
Second Accessory      yellow      +      ignition switch
Keysense      RED / black      +      ignition key switch
Power Lock      GREEN/ red to BLACK/ blue      -1000 ohms      driver kick or PJB, brown 32 pin plug (J-06), pin T
Notes: The PJB (Passenger Junction Box) is behind the glove box.
Power Unlock      same as power lock      -
Lock Motor      yellow/black      5 wire      driver kick or PJB, 46 pin plug (J-05), pin AP
Unlock Motor      WHITE/ black      5 wire      driver kick or PJB, 46 pin plug (J-05), pin L
Parking Lights+      ORANGE / white (L), orange (R)      +      passenger kick or PJB, 46 pin plug (J-05), pins G and AS
Parking Lights-      BLACK/ white      -      light switch or PJB, 46 pin plug (J-03), pin I
Hazards      BLACK/ orange      -      hazard switch or PJB, blue 32 pin plug (J-04), pin AC
Turn Signal(L)      blue      +      passenger kick or PJB, 46 pin plug (J-05), pin A
Turn Signal(R)      blue/red      +      passenger kick or PJB, 46 pin plug (J-05), pin AK
Reverse Light      GREEN/ orange (4 door), GREEN/ black (5 door)      +      passenger kick or PJB, 46 pin plug (J-05), pin C
Door Trigger      BLACK / YELLOW      - N.C.      driver kick or PJB, brown 32 pin plug (J-06), pin W
Dome Supervision      BLACK/ blue      -      passenger kick or PJB, 46 pin plug (J-05), pin U
Trunk/Hatch Pin      BLACK/ red      -      pass kick or PJB, brn 32 pin plug (J-06), pin Z (4 door) or X (5 door)
Hood Pin      BLACK / YELLOW      - N.C.      hood switch or PJB, green 32 pin plug (J-02), pin Y
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      BLACK/ blue      -      driver kick or PJB, brown 32 pin plug (J-06), pin Y
Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm      BLACK/ white      -      driver kick or PJB, brown 32 pin plug (J-06), pin AA
Disarm No Unlock      use keysense
Tachometer      BLACK/ stripe (non-turbo) or GREEN/ stripe (turbo)      ac      any fuel injector
Wait to start      N/A
Brake Wire      RED / white to RED / yellow      +      brake switch, driver kick, or PJB, 46 pin plug (J-05), pin M
Parking Brake      BLACK/ lt. green      -      parking brake switch or PJB, blue 32 pin plug (J-04), pin AB
Horn Trigger      black      -      horn switch or PJB, blue 32 pin plug (J-04), pin N
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
donovansadv
Posted: February 20, 2013 at 8:09 AM / IP Logged
Thank you very much for your time.
