2007 mitsubishi raider truck wiring
bobby337
Member - Posts: 11
Posted: May 18, 2013 at 10:42 AM / IP Logged
Can I get the alarm wiring diagram and also how to wire a single wire door lock for this car?
Posted: May 18, 2013 at 11:24 AM / IP Logged
Dodge Dakota.
tonanzith
Gold - Posts: 603
Posted: May 18, 2013 at 6:02 PM / IP Logged
The IPM (Integrated Power Module) is in the engine compartment, on the driver fender.
Second 12 Volts     lt. blue/red (20A)     +     ignition switch, black 6 pin plug, pin 6
Starter     yellow/gray (not for remote start)     +     driver fender, gray 1 pin plug or IPM, brown 40 pin plug, pin 9
Second Starter     PURPLE / brown     - 180 ohms     ignition switch, black 6 pin plug, pin 2
If interface module is not available, see Tech Doc 1084 for wiring information.
Ignition     pink/gray     +     ignition switch, black 6 pin plug, pin 3
Second Ignition     N/A
Third Ignition     N/A
Accessory     same as second starter     - 560 ohms
Second Accessory     N/A
Third Accessory     N/A
Keysense     same as second starter     -8.5K ohms
Data Bus     N/A
Can Bus High     WHITE/ orange     data     SKREEM, black 8 pin plug, pin 6
The SKREEM (Sentry Key Remote Entry Module) is around the ignition key switch.
Can Bus Low     white     data     SKREEM, black 8 pin plug, pin 7
Can Bus Sw     N/A
Power Lock     PURPLE / dk. green     - 330 ohms     driver kick or instrument cluster, gray 16 pin plug, pin 3
Power Unlock     same as power lock     - 100 ohms
Lock Motor     lt. green     5 wire     driver kick or instrument cluster, gray 26 pin plug, pin 15
Driver Unlock Motor     tan/lt. green     5 wire     driver kick or instrument cluster, gray 26 pin plug, pin 12
Passenger Unlock Motor     PURPLE / black     5 wire     passenger kick or instrument cluster, gray 26 pin plug, pin 25
Parking Lights (-)     pink/red     -1130 ohms     headlight switch or instrument cluster, gray 16 pin plug, pin 5
Parking Lights (+)     pink/red (L), WHITE/ orange (R)     +     IPM, black 20 pin plug, pins 15 and 17
Hazards     WHITE/ orange     - 120 ohms     hazard switch or instrument cluster, gray 16 pin plug, pin 8
Turn Signal (Left)     WHITE/ lt. green (F), WHITE/ dk. green (R)     +     FCM, black 12 pin plug, pin 10; IPM, brown 40 pin plug, pin 37
The FCM (Front Control Module) is attached to the IPM (Integrated Power Module) in the engine compartment, on the driver fender.
Turn Signal (Right)     WHITE/ tan (F), WHITE/ orange (R)     +     FCM, black 12 pin plug, pin 8; IPM, gray 40 pin plug, pin 35
Headlight     pink/red     - 660 ohms     headlight switch or instrument cluster, gray 16 pin plug, pin 5
AutoLights     N/A
Reverse Light     WHITE/ lt. green     +     IPM, brown 40 pin plug, pin 27
The IPM (Integrated Power Module) is in the engine compartment, on the driver fender. Also found in the driver A pillar on vehicles with auto-dimming inside rearview mirror.
Left Front Door Trigger     purple     -     dr kick or instr cluster, gray 26 pin plug, pin 6
Right Front Door Trigger     PURPLE / white     -     dr kick or instr cluster, white 26 pin plg, pin 23
Left Rear Door Trigger     PURPLE / gray     -     dr kick or instr cluster, gray 26 pin plug, pin 8
Right Rear Door Trigger     purple / YELLOW     -     dr kick or instr cluster, white 26 pin plg, pin 22
Dome Supervision     yellow/orange     +     passenger A pillar or instrument cluster, white 26 pin plug, pin 11
Trunk/Hatch Pin     N/A
Rear Glass Pin     N/A
Hood Pin     PURPLE / lt. blue     -     hood switch or IPM, white 20 pin plug, pin 16
Trunk/Hatch Release     N/A
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     factory remote only
Disarm No Unlock     Sentry Key, ignition, and keysense
Trunk Alarm Shunt     N/A
Tachometer     NOT red     ac     any fuel injector
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     black (in), yellow/dk. blue (out)     - N.O.     clutch pedal switch
Fuel Pump     dk. blue/orange     +     IPM, gray 40 pin plug, pin 15
Rear Defroster     dk. blue/white to BLACK/ dk. green     + latched     driver kick, harness to rear
Mirror Defroster     dk. blue/gray     + latched     driver kick, door harness
Left Front Heated Seat     lt. GREEN/ brown     5 wire     left heated seat switch, green 6 pin plug, pin 3
Right Front Heated Seat     lt. GREEN/ purple     5 wire     right heated seat switch, gray 6 pin plug, pin 3
Speed Sense     yellow/pink or yellow/black     ac     PCM, top plug, pin 32
The PCM (Powertrain Control Module) is in the engine compartment, on the passenger fender.
Brake Wire     WHITE/ lt. blue     +     brake pedal switch or driver kick, harness to rear
Parking Brake     dk. GREEN / WHITE     -     parking brake switch or instrument cluster, gray 26 pin plug, pin 3
Horn Trigger     dk. GREEN/ purple     -     horn switch or instrument cluster, gray 26 pin plug, pin 10
Wipers     BROWN / white (L), BROWN / orange (H)     +     wiper motor or IPM, brown 40 pin plug, pins 32 and 25
Left Front Window (Up/Down)     ORANGE / lt. green - ORANGE / white     A     driver window switch, gray 8 pin plug, pins 7 and 6
Right Front Window (Up/Down)     ORANGE / tan - ORANGE / gray     A     driver kick, door harness
Left Rear Window (Up/Down)     ORANGE / black - ORANGE / red     A     driver kick, door harness
Right Rear Window (Up/Down)     tan / YELLOW - ORANGE / dk. blue     A     driver kick, door harness
Sun Roof (Open/Close)     motor part of module
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     RED / black     +     radio, gray 22 pin plug, pins 1 and 12
Radio Ground     BLACK/ lt. green and black     -     radio, gray 22 pin plug, pins 11 and 22
Radio Ignition     (CAN BUS)
Radio Illumination     (CAN BUS)
Factory Amp Turn-on     dk. green (subwoofer amp)     +     radio, gray 22 pin plug, pin 13
Power Antenna     N/A
Left Front Speaker (+/-)     dk. green - dk. GREEN/ brown     +,-     radio, gray 22 pin plug, pins 10 and 9
If equipped, the amplifier is in the passenger kick. On vehicles with amplifier, the speaker wires are gray/purple - gray / YELLOW at the amplifier, white 14 pin plug, pins 1 and 7. The tweeter wires are gray/orange - gray / YELLOW at the amplifier, white 14 pin plug, pins 5 and 13.
Right Front Speaker (+/-)     gray - gray/brown     +,-     radio, gray 22 pin plug, pins 7 and 8
If equipped, the amplifier is in the passenger kick. On vehicles with amplifier, the speaker wires are dk. GREEN/ purple - dk. GREEN/ YELLOW at the amplifier, white 14 pin plug, pins 2 and 8. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 14 pin plug, pins 6 and 14.
Left Rear Speaker (+/-)     dk. GREEN/ dk. blue - dk. GREEN/ orange     +,-     radio, gray 22 pin plug, pins 18 and 19
If equipped, the amplifier is in the passenger kick. On vehicles with amplifier, the speaker wires are gray/lt. green - gray/dk. green at the amplifier, white 14 pin plug, pins 3 and 9.
Right Rear Speaker (+/-)     gray/dk. blue - gray/orange     +,-     radio, gray 22 pin plug, pins 21 and 20
If equipped, the amplifier is in the passenger kick. On vehicles with amplifier, the speaker wires are dk. GREEN/ lt. green - lt. GREEN/ gray at the amplifier, white 14 pin plug, pins 4 and 12.
Center Channel (+/-)     N/A
Subwoofer (+/-)     gry/brn - dk grn/brn (1), gry/wht - dk grn/wht (2)     +,-     amplifier, white 20 pin plug, pins 1 and 10 (1), 2 and 11 (2)
Aux. Audio Input Left (+/-)     N/A
Aux. Audio Input Right (+/-)     N/A
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     RED / black     +     Satellite Receiver, black 12 pin plug, pin 1
If equipped, the Satellite Receiver is on the driver side rear floor.
Satellite Radio Ground     BLACK/ dk. blue     -     Satellite Receiver, black 12 pin plug, pin 3
Satellite Radio Ignition     (CAN BUS)
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     dk. GREEN/ orange - dk. green (common)     +,-     Satellite Receiver, black 12 pin plug, pins 6, 11
Satellite Audio Right (+/-)     dk. GREEN/ lt. blue - dk. green (common)     +,-     Satellite Receiver, black 12 pin plug, pins 12, 11
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.5 left front door
Left Front Tweeter   left front door
Right Front Speaker     6.5 right front door
Right Front Tweeter   right front door
Left Rear Speaker     6.5 left rear door or side panel
Left Rear Tweeter     N/A
Right Rear Speaker     6.5 right rear door or side panel
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer   center rear floor
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Gary Sather
bobby337
Member - Posts: 11
Posted: June 25, 2013 at 12:15 AM / IP Logged
Thank you. Got the door lock done but had problem locating the parking light. Oh well
lucasoil4u
Copper - Posts: 317
Posted: July 02, 2013 at 2:14 PM / IP Logged
Try harder dont give up and do a 75% installed job.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
