wired correctly, whats the issue then?
xconcepts
Posted: May 20, 2013 at 11:53 AM / IP Logged
Ok so I've had my alarm installed for about 2 years.  Its a Dowentec pushbutton/alarm, S Korean brand.  I have 2 sirens installed, one in the engine bay and a piezo under the dash.  Over the last 6 months the one in the engine bay has been working half the time, it would only chirp half of the chirp.  Finally it stopped working and I figured it went bad for one reason or another.  So I tried another siren a buddy had that I know worked, still nothing, so I tested the old siren on a battery and its still good.
I tested the wires at the siren and don't have any voltage and figured the output might be bad but then the other siren shouldn't work.  I'm wired this way; brain to a relay to the siren in the engine bay, the 2nd piezo siren is tapped into the wiring after the relay.
I tested voltage at the tapped wire and have voltage before and after, however nothing after the firewall.  I cannot see where the wire is coming from the firewall if there is a cut/splice/grounding out.  So my question is 1) Am I wired correctly for the 2 sirens?  2) Can I run a wire from where I know I have voltage to the siren to make sure it works and if so keep it hooked up that way?
Posted: May 20, 2013 at 12:38 PM / IP Logged
Waste of time checking voltages, run a siren from the output immediately before and after the relay that eliminate or not the alarm and the relay.
xconcepts
Posted: May 20, 2013 at 3:50 PM / IP Logged
So I'm good though wiring 2 sirens with the single relay?
Posted: May 20, 2013 at 4:30 PM / IP Logged
Of course.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
