06 kia spectra alarm door lock relay
toolzoneplus
Member - Posts: 16
Posted: May 25, 2013 at 3:41 PM / IP Logged
My wife owns a 06 Kia spectra5 and it has been alot of years since I have installed alarm, in fact the last one I did was my 79 Corvette with power door locks and power windows and used relays for the corvette but I can not remember how to wire up door locks. I have relays and need to figure out how to wire 2 relays to the door lock and unlock wires, I know the color codes to use which I found on this forum but do not have the relay wiring and which wire goes to 12 volt hot,ground and which one goes to lock and unlock wires is there a diagram we can follow
Mwsounds
Copper - Posts: 61
Posted: May 25, 2013 at 5:23 PM / IP Logged
This web site has those diagrams...
https://www.the12volt.com/doorlocks/page3.asp#5w
There are all the types of diagrams you would need. If you are using two relays, it should be the diagram for the 5 wire set up.
When I did my 2000 Kia Sephia, I added an aftermarket actuator to the drivers door, and that actuated the other locks to either lock or unlock.
The tech sheet says:
Power Lock     yellow/orange      -     driver kick, door harness
Power Unlock     yellow/black      -     driver kick, door harness
You should be able to apply a negative output from the alarm to these wires and it will actuate the lock or unlock feature. YOu should not need relays for this install.
I hope this helps.
Thanks,
Mike Ward
Get it done right the first time!
toolzoneplus
Member - Posts: 16
Posted: May 26, 2013 at 9:14 PM / IP Logged
So I am guessing the factory default from the 2 wires or blue and green are postive output and I need to make them negative output correct?
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
