2013 acura mdx
Ht3kn1c
Member - Posts: 10
Posted: June 05, 2013 at 9:17 PM / IP Logged
Does anyone have a remote start/alarm wire diagram for this vehicle?
tonanzith
Gold - Posts: 603
Posted: June 05, 2013 at 9:25 PM / IP Logged
The one I just did was the same as the 2012.
Also, you WILL need a db-all or xk09 or equivalent for the bypass.
12 Volts     white (50A)     +     ignition switch, brown 7 pin plug, pin 3
Second 12 Volts     N/A
Starter     yellow     +     ignition switch, brown 7 pin plug, pin 1
Second Starter     N/A
Ignition     pink     +     ignition switch, brown 7 pin plug, pin 6
Second Ignition     N/A
Third Ignition     N/A
Accessory     orange     +     ignition switch, brown 7 pin plug, pin 4
Second Accessory     red     +     ignition switch, brown 7 pin plug, pin 5
Third Accessory     N/A
Keysense     pink     -     ignition key sw, grn 6 pin plug, pin 1 or MICU, grn 30 pin plug, pin 13
The MICU (Multiplex Integrated Control Unit) is part of the dash fuse box in the driver kick. It has two plugs on the edge of the fuse box facing the rear of the vehicle.
Data Bus     lt. green (S-NET immobilizer data)     data     Immobilizer Control Unit, green 7 pin plug, pin 3
The Immobilizer Control Unit is around the ignition key switch. The immobilizer ignition is brown in pin 2, and ground is brown in pin 7.
Can Bus High     N/A
Can Bus Low     N/A
Can Bus Sw     lt. green (B-CAN)     data     Immobilizer Control Unit, green 7 pin plug, pin 4
The Immobilizer Control Unit is around the ignition key switch. Also found at the dash fuse box, green 21 pin plug (J), pin 4.
Power Lock     pink     +     driver door lock switch, green 5 pin plug, pin 4
Power Unlock     red     +     driver door lock switch, green 5 pin plug, pin 3
Lock Motor     brown     5 wire     dash fuse box, green 12 pin plug (K), pin 12
Driver Unlock Motor     gray     5 wire     dash fuse box, green 12 pin plug (K), pin 2
Passenger Unlock Motor     gray     5 wire     dash fuse box, GREEN / WHITE 45 pin plug (N), pin 9
Parking Lights (-)     brown     -     headlight switch, green 10 pin plug, pin 3
Parking Lights (+)     gray     +     driver kick, harness to rear
Hazards     green     +     hazard switch, grn 6 pin plug, pin 5 or MICU, grn 30 pin plug, pin 28
Turn Signal (Left)     blue     +     driver kick, harness to rear
Turn Signal (Right)     brown     +     driver kick, harness to rear
Headlight     blue or white     -     headlight sw, grn 10 pin plug, pin 9 or MICU, grn 30 pin plug, pin 3
AutoLights     yellow (ground to turn off autolights)     -     headlight switch, green 10 pin plug, pin 4
Reverse Light     brown     +     driver kick, harness to rear or MICU, green 30 pin plug, pin 5
Left Front Door Trigger     green     -     driver kick, harness to rear
Right Front Door Trigger     lt. green     -     driver kick, harness to rear
Left Rear Door Trigger     green     -     driver kick, harness to rear
Right Rear Door Trigger     gray     -     driver kick, harness to rear
Dome Supervision     lt. green     -     dash fuse box, green 39 pin plug (X), pin 9
Trunk/Hatch Pin     lt. green     -     rear fuse box, GREEN / WHITE 42 pin plug (C), pin 6
The rear fuse box is in the left rear quarter panel.
Rear Glass Pin     N/A
Hood Pin     yellow/red to green     -     hood switch
Trunk/Hatch Release     brown and white (power tailgate)     short     dash fuse box, green 21 pin plug (J), pins 18 and 6
These two wires are connected when the power tailgate switch on the door is pressed.
Trunk Release Motor     N/A
Fuel Door Release     lt. blue     5 wire     rear fuse box, WHITE/ green 34 pin plug (B), pin 28
The rear fuse box is in the left rear quarter panel. Can also use pink (-) at the fuel door opener switch, green 7 pin plug, pin 1.
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     lt. blue (driver door key cylinder)     -     driver door key cylinder switch, white 10 pin plug, pin 9
Factory Alarm Disarm     blue (driver door key cylinder)     -     driver door key cylinder switch, white 10 pin plug, pin 8
Disarm No Unlock     see factory alarm disarm
Trunk Alarm Shunt     N/A
Tachometer     brown, red, blue, yellow, BLACK/ red, or WHITE/ blue     ac     any fuel injector, gray 2 pin plug, pin 1
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     yellow     +     driver kick, harness to rear
Rear Defroster     red     + latched     rear fuse box, GREEN / WHITE 42 pin plug (C), pin 22
Mirror Defroster     gray to black (L), green to black (R)     + latched     each front door panel, white 16 pin plug, pin 1
Left Front Heated Seat     lt. green (without ventilated seat)     5 wire     driver seat heater switch, blue 6 pin plug, pin 3
Right Front Heated Seat     green (without ventilated seat)     5 wire     passenger seat heater switch, gray 6 pin plug, pin 3
Speed Sense     blue (some models only)     ac     passenger kick, white 34 pin plug, pin 17
Brake Wire     lt. green     +     brake switch or dash fuse box, grn/wht 45 pin plug (N), pin 21
Parking Brake     orange     -     parking brake sw or dash fuse box, grn/wht 45 pin plug (N), pin 44
Horn Trigger     orange     -     horn switch, white 20 pin plug, pin 2
Wipers     pink     -     wiper switch, BLACK/ white 8 pin plug, pin 5
Left Front Window (Up/Down)     use factory alarm arm/disarm
Right Front Window (Up/Down)     see left front window
Left Rear Window (Up/Down)     see left front window
Right Rear Window (Up/Down)     see left front window
Sun Roof (Open/Close)     use factory alarm arm/disarm
Sun Roof (Limit/Close)     N/A
Memory Seat 1     green     -     memory switch, green 10 pin plug, pin 7
Memory Seat 2     red     -     memory switch, green 10 pin plug, pin 5
Memory Seat 3     N/A
Radio 12V     white     +     radio, gray 17 pin plug, pin 17 or gray 24 pin plug, pin 24
Radio Ground     black     -     radio, gray 17 pin plug, pin 9 or gray 24 pin plug, pin 12
Radio Ignition     purple     +     radio, gray 17 pin plug, pin 14 or gray 24 pin plug, pin 14
Radio Illumination     (B-CAN, base model); yellow (except base model)     + dimmer     radio, gray 28 pin plug, pin 4
Factory Amp Turn-on     lt. green     +     radio, gray 32 pin plug, pin 23 or gray 24 pin plug, pin 17
Power Antenna     black     +     radio, gray 3 pin plug, pin 3
Left Front Speaker (+/-)     green - red (preamp)     +,-     radio, gray 32 pin plug, pins 24, 8 or gray 24 pin plug, pins 23, 22
The amplifier is under the passenger dash, behind the glove box. The speaker wires are white - green at the amplifier, gray 18 pin plug, pins 11 and 2 (base model), or 16 and 7 (except base model).
Right Front Speaker (+/-)     blue - pink (preamp)     +,-     radio, gray 32 pin plug, pins 26, 10 or gray 24 pin plug, pins 19, 18
The amplifier is under the passenger dash, behind the glove box. The speaker wires are red - brown at the amplifier, gray 18 pin plug, pins 15 and 6.
Left Rear Speaker (+/-)     lt. blue - purple (preamp)     +,-     radio, gray 32 pin plug, pins 27, 11 or gray 24 pin plug, pins 11, 10
The amplifier is under the passenger dash, behind the glove box. The speaker wires are pink - purple at the amplifier, gray 18 pin plug, pins 10 and 1 (base model), or 13 and 4 (except base model). The rear surround speaker wires are blue - gray at the amplifier, gray 18 pin plug, pins 17 and 8 (except base model).
Right Rear Speaker (+/-)     brown - yellow (preamp)     +,-     radio, gray 32 pin plug, pins 29, 13 or gray 24 pin plug, pins 7, 6
The amplifier is under the passenger dash, behind the glove box. The speaker wires are blue - orange at the amplifier, gray 18 pin plug, pins 14 and 5 (base model), or 12 and 3 (except base model). The rear surround speaker wires are red - black at the amplifier, gray 18 pin plug, pins 14 and 5 (except base model).
Center Channel (+/-)     blue - pink (preamp)     +,-     radio, gray 32 pin plug, pins 32, 16 or gray 24 pin plug, pins 10, 9
The amplifier is under the passenger dash, behind the glove box. The speaker wires are black - pink at the amplifier, gray 18 pin plug, pins 16 and 7 (base model), or 11 and 2 (except base model).
Subwoofer (+/-)     green - red (preamp)     +,-     radio, gray 32 pin plug, pins 30, 14 or gray 24 pin plug, pins 12, 24
The amplifier is under the passenger dash, behind the glove box. The speaker wires are blue - gray (1); red - black (2) at the amplifier, gray 18 pin plug, pins 12 and 3; 17 and 8 (base model), or blue - pink at the amplifier, gray 18 pin plug, pins 10 and 1 (except base model).
Aux. Audio Input Left (+/-)     white - red     +,-     radio, gray 24 pin plug, pins 14 and 1 or 1 and 2
Aux. Audio Input Right (+/-)     black - red     +,-     radio, gray 24 pin plug, pins 13 and 1 or 13 and 2
RSE Video (+/-)     blue - pink     +,-     radio, gray 16 pin plug, pins 11 and 10
RSE Audio Left (+/-)     red - white     +,-     radio, gray 16 pin plug, pins 6 and 13
RSE Audio Right (+/-)     black - white     +,-     radio, gray 16 pin plug, pins 14 and 13
Satellite Radio 12 Volts     white     +     XM Receiver, white 14 pin plug, pin 1
If equipped, the XM Receiver is in the right side of the cargo area.
Satellite Radio Ground     black     -     XM Receiver, white 14 pin plug, pin 11
Satellite Radio Ignition     red     +     XM Receiver, white 14 pin plug, pin 2
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     black - green     +,-     XM Receiver, white 14 pin plug, pins 6 and 14
Satellite Audio Right (+/-)     red - white     +,-     XM Receiver, white 14 pin plug, pins 5 and 13
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.5     3.8     left front door
Left Front Tweeter     1     2     left front dash
Right Front Speaker     6.5     3.8     right front door
Right Front Tweeter     1     2     right front dash
Left Rear Speaker     6.5     3.8     left rear door
Left Rear Tweeter     3.5     3     left rear pillar
Right Rear Speaker     6.5     3.8     right rear door
Right Rear Tweeter     3.5     3     right rear pillar
Center Channel   top center of dash
Subwoofer     10     4.5     right side of cargo area
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner   right side of cargo area
Gary Sather
Ht3kn1c
Member - Posts: 10
Posted: June 05, 2013 at 10:52 PM / IP Logged
Thank you!
Tuesday, October 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
