2013 kia rio wiring schematic
vader7071
Member - Posts: 11
Posted: June 14, 2013 at 5:31 PM / IP Logged
I have found the wire list from the DEI site (ready remote) for the Kia Rio 2013, but what I would like is the wiring diagram for the whole car if possible, or at least the location of the connections they refer to from Ready Remote. Thank you.
I am currently installing after market keyless (in a car that does not have factory door locks) and will probably be installing other items later on as well.
There is no devil, only God when He is drinking.
Ween
Platinum - Posts: 1,366
Posted: June 15, 2013 at 9:16 AM / IP Logged
hi,
http://www.kiatechinfo.com...sign up and you should be able to get any info you need.
mark
vader7071
Member - Posts: 11
Posted: June 16, 2013 at 9:51 AM / IP Logged
Just signed up and looking through. Not quite everything I want, but it does have some good information. Thanks. Just wish I still had access to AllDataPro.
Ween
Posted: June 16, 2013 at 10:21 AM / IP Logged
considering it's free, and is generated by Kia themselves?
did you use the ETM section and download a SVG viewer program?
vader7071
Member - Posts: 11
Posted: June 16, 2013 at 1:01 PM / IP Logged
I did not see an ETM section. What is it under?
Ween
Posted: June 16, 2013 at 1:14 PM / IP Logged
click service info (SI), select your vehicle.
it will show 'Shop' beneath the Service Info (SI).
On the right, there are selections (books): Shop, ETM,
DTC, Replace, Component.
Download the Adobe SVG Viewer, select desired book.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
