2013 dodge dart no start
offroadzj
Gold - Posts: 2,043
Posted: July 18, 2013 at 9:00 PM / IP Logged
I know this is a shot in the dark since iData JUST released the firmware for this, but have any of you guys successfully put a starter in a 2013 Dart M/T? I just finished up one for my brother as a graduation gift (corrections academy) and all of the security / convenience features work great but when I try to remote start it (after a successful ready mode) the ignition kicks on and the LED flashes blue. After a second or so the relays click, the radio turns off (ACC), and the LED on the iData turns solid red but the vehicle starter does not crank. It repeats for all 3 attempts but never is able to start. I double checked all of the connections and they are correct... and all soldered. I also tried using a manual brake input instead of data and that does not fix the issue either.
Any other ideas???
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
dasbogie
Silver - Posts: 514
Posted: July 19, 2013 at 8:46 AM / IP Logged
I'm sure these are things you thought of already but tach programmed or run your own tach wire? Did you try holding in the clutch pedal?
Is there a key light on the gauge cluster yelling at you?
Advanced
offroadzj
Gold - Posts: 2,043
Posted: July 19, 2013 at 9:52 AM / IP Logged
Tach is good because it can go into ready mode, tried the clutch, and the red light on the dash turns off and does not flash.... the only thing I did differently from the iData install manual is that I grounded it to a bolt under the dash instead of the ignition module. It looks like there might be a "buffer" piece of plastic between the day frame and the body, so I might try changing the ground and see if it fixes the issue.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
