hifonics brutus amp pioneer champ series
nysean91
Posted: August 12, 2013 at 10:09 PM / IP Logged
So Ive got a hifonics brutus series amp 2008d. 2000w mono block. Rms rating at 650x1at 4ohm 1300x1@ 2 ohm 2000x1 @ 1 ohm
The subs I have are 2 12inch pioneer champ series subs 4 ohm dvs 400rms.
Now what would be the best way to wire them up to the amp. Right now I have it set for 4 ohms but I was curious is there any possible way to wire the 2 subs down to 2 ohms into a monoblock amp. Ive looked and havent found anything .
nysean91
Posted: August 12, 2013 at 10:27 PM / IP Logged
I meant dvc
KPierson
Platinum - Posts: 3,527
Posted: August 13, 2013 at 1:01 PM / IP Logged
You can wire them at 4 ohm (paralleled coils, then series each speaker) or 1 ohm (parallel coils, then parallel each speaker). With what you have there is no way to go 2 ohms - you would need 4 ohm svc speakers to do that with a monoblock amp.
Kevin Pierson
