sidewinder 6500esp on qx4
infinitiqx4
Member - Posts: 8
Posted: May 13, 2003 at 2:58 PM / IP Logged
Hello All, I am new here and this is my 1st post.
I installed the 6500 and the 555u but i cannot get my remote start to work.  The closest I got was to have it turn on immediately after i turned it off with the key.  Am I supposed to ground the blue wire?  Where can I get a good tach wire(color)?  Should I just use voltage sensing?  I don't know what to try now.  I hope you can help cause I had a guy at Good Guys try to make it work but he could not do it.
car=2001 infiniti QX4
alarm=sidewinder 6500esp w/555u
jaxman
Copper - Posts: 185
Posted: May 13, 2003 at 3:19 PM / IP Logged
About which blue wire you talk ? The one from the System or the one from the 555U ?
The blue one from the 555U should be connected with the blue status wire from the alarm system.
What happends when you try to start ? Does the engine turn or not ?
A few details would help.
infinitiqx4
Member - Posts: 8
Posted: May 13, 2003 at 3:55 PM / IP Logged
sorry for the lack of details.  the starter cranks but the engine does not start and it will keep on trying to start until I deactivate the remote start. I was talking about the blue wire on the system cause someone had mentioned to me that I might need to ground it.  I've also tried to see if it would start with the key in but it would not start.
jaxman
Copper - Posts: 185
Posted: May 14, 2003 at 1:17 AM / IP Logged
If the car would not start even with the ignition key on then it might be an ignition problem or a tach signal problem.
Try to turn the key to the ignition point then try to start the system with the remote. It will start ?
If yes then you have connected wrong some ignition/AC wires.
If it will not start then it is the tach / voltage sense.
Try to program the alarm for voltage sensing and try again. Will start ?
If not change the voltage checking from high to low and the other way around.
It will start ?
Let me know.
infinitiqx4
Member - Posts: 8
Posted: May 14, 2003 at 12:40 PM / IP Logged
I tried with the key to the ignition point and it still will not turn on.
It works fine only about 10secs after I have it learn the tach signal.
I am going to try the voltage sensing low and high now.  I'll let you know what happens.  Thx.
infinitiqx4
Member - Posts: 8
Posted: May 14, 2003 at 1:23 PM / IP Logged
Itried voltage sense low and high with the key in and with it in the ON possition but I was unable to get it to turn on.  This is getting pretty frustrating.  I really hope you guys can help me out.  So as it stands right now, the closest I've gotten to make my r/s work is with tach sensing immediately after learnign the tach.  Is it possible I might have the wrong tach wire?  I am using the WHITE/ green from the ECU by the steering column.sidewinder 6500esp on qx4 -- posted image.
jaxman
Copper - Posts: 185
Posted: May 14, 2003 at 5:01 PM / IP Logged
Well , I need to know if the STARTER will turn or not ??
Does the system TURN the engine or not ?
If you use current sensing then you don't have to use also the tach. Only one can be used , tach or voltage sensing.
jaxman
Copper - Posts: 185
Posted: May 14, 2003 at 5:02 PM / IP Logged
Do you have a ground on the thin BLACK/ white wire ?
infinitiqx4
Member - Posts: 8
Posted: May 15, 2003 at 12:57 PM / IP Logged
The starter is turning every time.  The engine is cranking fine, but it just will not start.  It acts as if it were lacking fuel but like I said, it will start only seconds after learning the tach.  When I programmed it to voltage sensing, I did not remove the tach wire from the tach source on the vehicle.  Should I have??
Also my BLACK/ white wire for neutral safety switch is connected to ground directly.  Should it not be??
P.S.  Thanx for your help with this problem I am having.  I'm sure it is something dumb that I missed.
