2009 corolla door tigger wiring
facingfear
Posted: October 28, 2013 at 7:49 AM / IP Logged
I am trying to wire the door trigger wire, either green or violet,from a viper 3203 to a 2009 corolla. I have tried all the possible combinations in wiring either the green or violet wire to the wires in the 6pin connector (white, WHITE/ red) but still have no luck in getting the alarm to go off when i open the door. Any advice or walkthrough? I posted this question in a another website forum two years ago, which no one answering, and just recently where someone suggested i try this site. Any advice would be appreciated. thanks.
smokeman1
Platinum - Posts: 1,589
Posted: October 28, 2013 at 8:04 AM / IP Logged
Bulldog list the door trigger wire as:
purple (-) @ DASH FUSEBOX, PIN 21 IN WHITE 30-PIN PLUG(A)
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
facingfear
Posted: October 28, 2013 at 8:10 AM / IP Logged
Thanks. Would you suggest i dont try to hook up the wire to the dome light supervision?
smokeman1
Posted: October 28, 2013 at 8:31 AM / IP Logged
Found this on a different web site. You could try the dome light supervision light. The listing below are for each door trigger. I don't know why the left rear is listed in the drivers kick panel. Could be an error. What wire is totally correct?
Left Front Door Trigger: purple (USA/CAN made); white (JPN made)
dash fuse box, white 30 pin plug (2A), pin 21
Right Front Door Trigger: beige (USA/CAN made); brown (JPN made)
dash fuse box, white 32 pin plug (2E), pin 20
Left Rear Door Trigger: black (USA/CAN made); lt. blue (JPN made)
driver kick, white 13 pin plug, pin 10
Right Rear Door Trigger: yellow (USA/CAN made); lt. green (JPN made)
dash fuse box, white 32 pin plug (2E), pin 19
Dome Supervision: gray (USA/CAN made); white (JPN made)
dash fuse box, white 6 pin plug (2K), pin 2
