voltage drops
widerides
Member - Posts: 16
Posted: October 28, 2013 at 8:56 PM / IP Logged
Hello,
I have a Jeep Wagoneer with a stock 63 amp alternator.
I have a 4 gauge wire going from my battery to my amps.
I use to run a smaller system with the same wiring.
Now I run a larger system with the same wiring as before.
The "new to me system" is one that came out of my friend's car.
He used the same amp wiring kit I have in my Jeep without issue for years.
Now the for the problem.
With the stereo on or off, my voltage will be at 14v for 5 seconds and then drop down to 12v for 2 seconds. Then back up to 14v and repeat.
When I disconnect the amps from my battery the problem goes away.
Do I need an alternator that puts out more amps?
Maybe a short?
What do you all think?
Thanks,
Forrest
KPierson
Platinum - Posts: 3,527
Posted: October 28, 2013 at 9:26 PM / IP Logged
63A? How much current does your "new to you" amp draw?
Kevin Pierson
Platinum - Posts: 13,720
Posted: October 28, 2013 at 9:34 PM / IP Logged
Does the amp play?
powerslave
Copper - Posts: 126
Posted: October 29, 2013 at 10:12 PM / IP Logged
A 63 amp alternator won't cut it with any amp that has a 30AMP or more fuse in it. 20Amps is even pushing it for that low output alternator. I would upgrade that alternator if you plan on anything at 1000 watts.
Also? I see a lot of people wanting help, but never post the type of equipment they're using; no brands or model numbers. It's almost impossible to make any kind of assessment without that information. Everyone has to guess, and that's no help.
oldspark
Gold - Posts: 4,913
Posted: October 29, 2013 at 11:07 PM / IP Logged
That the "voltage will be at 14v for 5 seconds and then drop down to 12v for 2 seconds. Then back up to 14v and repeat" suggests bad charging, though I'd expect only old external electro-mag regulators to bounce like that.
But internal electronic regulated alternators can still have intermittents or worn brushes.
Just in case it is faulty or you are thinking of a larger alternator anyway...
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
