2011 dodge journey remote start issue
desh187
Copper - Posts: 310
Posted: February 22, 2014 at 11:18 PM / IP Logged
A few months ago installed a Compustar alarm/remote start(CM5000) with Fortins Evo All with CHR3 t harness on a 2011 Dodge Journey PTS .
Issue is when remote starting alarm chirps 3x followed by 2 light flash(key in on position)
I have started with each component changing one at a time even it now has a newer CHR6 t harness with new Evo all with latest firmware.
If Evoall is used as a stand alone remote start,everything is fine but just because of alarm added in so have to use combo unit,thats when Compustar unit sees something and gives 2 light flash.(in Data link)
i dont know what else to try and have talked to both Firstech and Fortin Tech support but nothing has resolved.
I have even changed the 1amp diode on the ignition wire.
Any feedback with similar issues with be very much appreciated
Chris Luongo
Platinum - Posts: 3,746
Posted: February 23, 2014 at 7:17 AM / IP Logged
Which alarm is triggering, the factory or the Compustar?
If it's the Compustar, it should hopefully have a way of telling the customer what "zone" of the alarm was violated----door, shock sensor, ignition, et cetera. Try to see what that tells you.
desh187
Copper - Posts: 310
Posted: February 23, 2014 at 11:13 AM / IP Logged
There is no factory alarm and even compustar alarm works fine, issue is when remote starting (no start)3chirps are heard followed by 2 light flashes which in the manual says key in on position.
This vehicle has a push button start and proximity key is not even near vehicle when remote starting
freqsounds
Copper - Posts: 289
Posted: February 24, 2014 at 8:41 AM / IP Logged
The "key in ON position" is detected using the Ignition 1 wire. Can you verify this wire is where it needs to go? Also, do you have the diode installed in the right direction (common issue, don't feel bad)? The diode is isolating the output of the remote start from the input of the Evo All and the car.
No question is stupid or not worth asking. You were once a noob, right? :)
desh187
Copper - Posts: 310
Posted: February 24, 2014 at 5:48 PM / IP Logged
I took the pink/white wire in the driver kick panel and it tests exactly as fortin shows on its instructions with 1amp diode band side towards Compustars ignition wire
freqsounds
Copper - Posts: 289
Posted: February 24, 2014 at 5:51 PM / IP Logged
When you meter the wire, do you see a voltage?
desh187
Copper - Posts: 310
Posted: February 24, 2014 at 5:56 PM / IP Logged
Voltage only when ignition is on
freqsounds
Copper - Posts: 289
Posted: February 24, 2014 at 6:01 PM / IP Logged
Weird. Could be a bad brain or bypass. I'm out of ideas! Sorry!
desh187
Copper - Posts: 310
Posted: February 24, 2014 at 9:39 PM / IP Logged
Yes i agree as i ran out of ideas too after replacing everything on it.
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
