1999 rx300 viper 5704v and xk01
ripready
Posted: March 17, 2014 at 5:07 PM / IP Logged
Hi,
I'm installing a Viper 5704V into a RHD RX300. Actually technically what I have is a JDM Toyota Harrier. Doesn't have the transponder/theft deterrent in it as I can just cut a key and it will start.
I bought the XK01 bypass module using TOYDL firmware and I'm looking for either the Purple wire or a yellow/red wire in the driver kick according to the Directechs site for the XK01. I think since I don't have the transponder, I won't have the purple wire from the Immobilizer Module then I would be looking for the yellow/red wire which is the CAN BUS SW pin in the driver kick.
Has anyone used the XK01 in this car and is the wire the correct colour? Also, is it coming from the Body ECU or some other unit? Need to figure this out since the layout would be different from a LHD and RHD.
Any help would be greatly appreciated.
Henry
dasbogie
Silver - Posts: 514
Posted: March 17, 2014 at 6:52 PM / IP Logged
did you check the driver door harness?
Advanced
ripready
Posted: March 17, 2014 at 10:42 PM / IP Logged
I know there are other wires in the driver door harness that are used if I am not using he XK01 going directly to the Driver Door ECU. The wire I am looking for is specifically in the kick panel according to the Directechs site.
howie (aka: harryharris)
Silver - Posts: 355
Posted: March 18, 2014 at 2:54 PM / IP Logged
Can I ask a silly question here?
If it doesn't have an immobiliser why are you bothering with an XK01?
BTW that vehicle is so easy, lock and unlock are in the driver's door loom at rear going to motoe, NEG pulse, extend the time for comfort close.
Test before boxing up.
ripready
Posted: March 18, 2014 at 3:38 PM / IP Logged
Actually I first used the XK01 because I thought I had an immobilizer installed and according to the directed technotes, I needed to use relays and diodes to lock/unlock the doors.
So, even if I didn't have the immobilizer, I could still use the XK01 for purely the door locks.
From what I read, it seems as those the relays aren't required as per the tech notes.
Silver - Posts: 355
Posted: March 18, 2014 at 3:41 PM / IP Logged
Those instructions are wrong, depending on model, have the door panel off and at the rear ground two of those wires (via an incandescent test bulb) you should get lock and unlock.
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
