avital 4x03 remote start, 98 lexus gs400
kastenbm
Member - Posts: 19
Posted: March 18, 2014 at 12:09 PM / IP Logged
Im new to this forum, so to anyone reading any help would be greatly appreciated!
I installed the avital remote start system in my 98 lexus gs400. The avital box an manual say model 4113 an the module says 4x03. Got everything hooked up an I can't get it to do anything...remote start will not program, status light will not come on at all, parking lights not flashing, etc. Everything is properly connected to best of my knowledge. Any ideas, thoughts, advice would be appreciated! Thanks
ccaudio
Copper - Posts: 52
Posted: March 18, 2014 at 1:29 PM / IP Logged
You have to make sure the antenna is plugged in for anything to work. Or I would check all my connections again
kastenbm
Member - Posts: 19
Posted: March 18, 2014 at 1:34 PM / IP Logged
It definitely is plugged in. I also tried a different ground just to be sure, that didn't change anything. I'll triple check my connections though to make sure they're correct.
chev104275
Gold - Posts: 1,436
Posted: March 18, 2014 at 2:22 PM / IP Logged
Can you list out your connections for us please
blanx218
Silver - Posts: 654
Posted: March 18, 2014 at 3:29 PM / IP Logged
Tap the WHITE/ blue wire to ground. If the car starts then it's a remote/antenna issue. If it doesn't then you have a power/ground issue or a defective brain.
kastenbm
Member - Posts: 19
Posted: March 18, 2014 at 3:54 PM / IP Logged
Connections made:
     Module | Car
(-) Lights< >yellow/red
(Output) IGN< >BLACK / YELLOW
(Output) STA< >black
(Output) ACC< >blue / YELLOW
(Input) 12v < >WHITE/ blue
Program (Output)
for IGN/ACC < >BLACK/ white
        Tach< >BLACK / YELLOW(eng.bay ECM)
   (+) Brake< >GREEN / WHITE
*hood pinswitch shutdown connected
*Ground connected with bolt on crash bar under dash
chev104275
Gold - Posts: 1,436
Posted: March 18, 2014 at 3:56 PM / IP Logged
Try what bland suggested
Where did you connect the BLACK/ white neutral safety shutdown wire ?
kastenbm
Member - Posts: 19
Posted: March 18, 2014 at 4:00 PM / IP Logged
I don't currently have that switch connected. I was told it wasn't necessary since my hood pinswitch shutdown wire was connected. Wasn't sure if it was a must have?
chev104275
Gold - Posts: 1,436
Posted: March 18, 2014 at 4:07 PM / IP Logged
The switch isn't but the wire is. If it's an automatic it should grounded. If it's a stick it needs to be connected to the ebrake.
kastenbm
Member - Posts: 19
Posted: March 18, 2014 at 4:35 PM / IP Logged
I wired the neutral safety switch wire to ground (without the toggle switch), still nothing. I tried touching the WHITE/ blue activation wire to ground, nothing happened there either.
Page of 4
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
