automatic sunroof closure with alarm
leigh.white
Member - Posts: 27
Posted: May 27, 2014 at 4:22 PM / IP Logged
The sunroof in my car has fully open and vent positions, it is hard wired with no one touch function, all wires to switch rest at ground except 12v supply, how would I use a window closure module to shut the roof from either of these positions? I can see how to wire for one way to shut as you would with a window but not sure how to do it for both ways? Thanks for any help.
leigh.white
Member - Posts: 27
Posted: May 27, 2014 at 4:23 PM / IP Logged
Sorry ment to say its a Peugeot 306 2000 yr model
Posted: May 27, 2014 at 4:29 PM / IP Logged
You can only use a window module if the close from open and close from vent has the same switch direction.
You need to find the motor wires and see if the same wire goes to 12 volts+ on slide close and vent close.
Can't help anymore, don't go near Peugeot/Renault/Citroen/Fiat to keep my sanity.
leigh.white
Member - Posts: 27
Posted: May 27, 2014 at 4:32 PM / IP Logged
No it uses different switch directions. This is what I thought. Is there any other way of doing it?
Posted: May 27, 2014 at 4:33 PM / IP Logged
No because being a Peugeot it wont be logical and even something like Autodata won't help because they changed colours every three months.
leigh.white
Member - Posts: 27
Posted: May 27, 2014 at 4:34 PM / IP Logged
Ha ha I work for Peugeot
Posted: May 27, 2014 at 4:37 PM / IP Logged
Then why don't you look up the circuit diagram, working for Peugeot would make me lose my sanity quicker than Spurs turn round their managers.
Having said that I've been using a new 3008 recently and I was very impressed, just waiting for the electrics to fail in the next two years.
Build quality and logical design were never French ideas.
leigh.white
Member - Posts: 27
Posted: May 27, 2014 at 4:40 PM / IP Logged
Yep I have the diagram but as you said the switch needs to be operated in diff directions for full closure and vent closure so really not sure how to go about wiring it?
2years? More like 2 months for it to go wrong! Ha ha
Posted: May 27, 2014 at 4:45 PM / IP Logged
You obviously know the reason why French cars are CRAP?
CitroenRenaultAndPeugeot.
Joking aside a single closer for two windows such as the DEI 529t will do it, just use one direction as one window the other direction as the other window but you'll need two outputs so say goodbye to Cobra, Meta etc. and use a Viper/Clifford etc.
leigh.white
Member - Posts: 27
Posted: May 27, 2014 at 4:50 PM / IP Logged
So using the ground when armed output is no good then, I would have liked it to shut all in one once I've hit the lock button-not fussy am I.yeh I've got the viper 5204v
Page of 3
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
