prostart goes into ready mode no attempt
schmooot
Member - Posts: 12
Posted: October 04, 2014 at 10:05 PM / IP Logged
Putting a prostart kit into a 2007 Caliber w/ manual trans with the DB-ALL bypass module.
The bypass is flashed with correct firmware and the starter is programmed to the transmitter and the tach is programmed. The yellow loop is not cut. The vehicle will go into ready mode (running > foot brake on > e-brake on >foot brake off > push button on transmitter > remove key > exit vehicle > shut off vehicle with fob) At this time all the triggers will pull it out of ready mode (doors, ebrake, foot brake)
When I attempt to start the car with fob it turns the ignition on, then flashes 3 times without a crank attempt. which according to the manual is brake circuit active or yellow loop (auto transmission only)
I don't understand how it goes into ready mode and the yellow loop is not cut and all the triggers are working yet it gives me an automatic transmission related error code without a start attempt.
Here is what I have tried in my troubleshooting:
-Different remote starter module
-Reflashed bypass module
-Reflashed bypass module and changed some options (Connected the parking brake and handbrake wires using w2w and disabled them in d2d programming)
-disconnected handbrake and foot brake and door triggers completely from vehicle and triggered them manually
-various other combinations of the above.
The only thing I have not done is created a full simulation on the bench.
Again the vehicle will go into ready mode (all triggers working correctly), it will also kick out of ready mode if any of its triggers are activated (as it should). So why no start attempt? and why the weird error code?
bat9905
Copper - Posts: 131
Posted: October 04, 2014 at 11:13 PM / IP Logged
Did you temporarily by pass clutch?
bat9905
schmooot
Member - Posts: 12
Posted: October 05, 2014 at 12:01 PM / IP Logged
dammit. You sir are my hero
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
