Posted: May 20, 2003 at 6:59 AM / IP Logged
Posted: May 20, 2003 at 7:14 AM / IP Logged
Posted: May 20, 2003 at 9:20 AM / IP Logged
Posted: May 20, 2003 at 9:22 AM / IP Logged
Posted: May 20, 2003 at 11:30 AM / IP Logged
Posted: May 20, 2003 at 9:43 PM / IP Logged
Posted: May 21, 2003 at 8:23 AM / IP Logged
Posted: May 21, 2003 at 9:49 AM / IP Logged
Posted: May 21, 2003 at 10:54 AM / IP Logged
Posted: May 21, 2003 at 11:16 AM / IP Logged
Thursday, May 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I think the only difference I had from that diagram (which you'll probably have to do, too) is I put pin 87 to ground instead of 12v+...this is because my horn needed a negative signal to work.
Write back with your results. Good luck!
