blink tail lights
eckoblaze72
Member - Posts: 22
Posted: May 20, 2003 at 8:09 AM / IP Logged
i want to know how do i change the rate of my tail light flahing. i know it i take the bulb out the front it blinks faster and vise versa. How do i do that without taking the bulb out?
deepdisshed
Member - Posts: 8
Posted: May 20, 2003 at 10:15 PM / IP Logged
You can buy an LED bulb for your car. It draws less power and your flasher will bling faster.
eckoblaze72
Member - Posts: 22
Posted: May 21, 2003 at 7:51 AM / IP Logged
DO you know what type of bulb it is???
dragracer
Member - Posts: 6
Posted: May 30, 2003 at 10:03 PM / IP Logged
the blinkers rate goes on a piece of metal going up and down. it goes up and down because of heat. when it is up it is off, and when it is down it is on. so when you take a bulb out it gets hotter faster, and goes faster. so ou can get leds or try to make the current higher
deepdisshed
Member - Posts: 8
Posted: May 30, 2003 at 11:05 PM / IP Logged
Its an LED bulb. you get it at autozone or just about any car store.
j r
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
