2012 toyota matrix key start
wyciwug
Copper - Posts: 156
Posted: December 06, 2014 at 2:26 PM / IP Logged
Hello
Does anyone have wiring diagram for 2012 Toyota Matrix to install remote car starter? Thanks
dcd
metz35
Copper - Posts: 458
Posted: December 06, 2014 at 4:19 PM / IP Logged
12volts      black (120A)      +      dash fuse box, white 1 pin plug (2G), pin 1
Starter      black      +      ignition switch, white 8 pin plug, pin 8
Second Starter      white (2.4L models only)      +      ignition switch, white 8 pin plug, pin 1
Ignition      brown      +      ignition switch, white 8 pin plug, pin 6
Second Ignition      green      +      ignition switch, white 8 pin plug, pin 4
Third Ignition      N/A
Accessory      gray      +      ignition switch, white 8 pin plug, pin 3
Second Accessory      N/A
Keysense      blue      -      ignition key switch or dash fuse box, white 32 pin plug (2E), pin 23
Power Lock      purple      -      driver kick, white 18 pin plug, pin 16
Notes: This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm arm wire.
Power Unlock      beige      -      driver kick, white 18 pin plug, pin 15
Notes: This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm disarm wire.
Lock Motor      beige      5 wire      driver kick, white 18 pin plug, pin 8
Unlock Motor      green      5 wire      driver kick, white 18 pin plug, pin 17
Parking Lights+      green      +      dash fuse box, white 30 pin plug (2A), pin 29
Parking Lights-      brown      -      headlight switch, white 20 pin plug, pin 18
Hazards      beige      -      hazard switch, gray 4 pin plug, pin 4
Turn Signal(L)      yellow      +      dash fuse box, white 30 pin plug (2A), pin 27
Turn Signal(R)      lt. blue      +      dash fuse box, white 30 pin plug (2A), pin 28
Reverse Light      red      +      dash fuse box, white 30 pin plug (2A), pin 30
Door Trigger      purple      -      dash fuse box, white 30 pin plug (2A), pin 21
Dome Supervision      gray      -      dash fuse box, white 6 pin plug (2K), pin 2
Trunk/Hatch Pin      lt. green      -      dash fuse box, white 30 pin plug (2A), pin 7
Hood Pin      N/A
Trunk/Hatch Release      locks/unlocks along with doors
Power Sliding Door      N/A
Factory Alarm Arm      black (driver door key lock)      -      driver kick, white 18 pin plug, pin 7
Factory Alarm Disarm      pink (driver door key unlock)      double -      driver kick, white 18 pin plug, pin 6
Disarm No Unlock      use keysense
Tachometer      gray      ac      data link connector, white 16 pin plug, pin 9
Wait to start      N/A
Brake Wire      blue      +      brake switch or dash fuse box, white 30 pin plug (2A), pin 9
Parking Brake      beige      -      dash fuse box, white 16 pin plug (2C), pin 5
Horn Trigger      lt. green      -      horn switch or dash fuse box, white 32 pin plug (2E), pin 5
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
