2013 accord cm7200
stroker351w
Member - Posts: 10
Posted: December 21, 2014 at 7:14 PM / IP Logged
I have the new 7200 that I'm putting in a manual transmission accord. Everything has been installed correctly and firmware has been updated and key cloned however I'm still running into a problem. I go through the sequence needed for a manual which puts it in reservation mode however I still get 7 clicks for an error which is Reservation Mode. Also, when I get out of the car it turns off but the power doesn't completly turn off. What could be the problem?
tedmond
Gold - Posts: 4,610
Posted: December 21, 2014 at 8:56 PM / IP Logged
First off, when using a 7x00 series brain on a manual transmission, you MUST use the FT-DAS.
Secondly, what bypass are you using ? You require a tach, door pin, ebrake and brake signal connected to the 7200.
Ted
Compustar Expert
stroker351w
Member - Posts: 10
Posted: December 21, 2014 at 10:56 PM / IP Logged
I'm using the integrated blade bypass
tedmond
Gold - Posts: 4,610
Posted: December 21, 2014 at 11:47 PM / IP Logged
what do you mean by it turns off but not completely off? pts?
Ted
Compustar Expert
stroker351w
Member - Posts: 10
Posted: December 30, 2014 at 7:34 AM / IP Logged
The car powers down once the door is shut however, it says "Power On" on the dash which means the accessory power is still on.
tedmond
Gold - Posts: 4,610
Posted: December 30, 2014 at 7:27 PM / IP Logged
double check your PTS connection. it should power the car down completely. Ive done a few without problems.
Ted
Compustar Expert
stroker351w
Member - Posts: 10
Posted: January 09, 2015 at 12:11 PM / IP Logged
Do you remember what color wire the PTS was on the harness? I have the schematics but I'd like to make sure.
tedmond
Gold - Posts: 4,610
Posted: January 09, 2015 at 4:54 PM / IP Logged
the pts wire is blue (+)
Ted
Compustar Expert
stroker351w
Member - Posts: 10
Posted: January 10, 2015 at 3:55 PM / IP Logged
The car is shutting down now however when I go to RS the car nothing happens. No clicks or flashes, nothing. The lock and unlock work properly so I know the canH abd canL are correct. Generally this would mean neutral safety or something like that isn't hooked up but that's on the older remote start.
tedmond
Gold - Posts: 4,610
Posted: January 10, 2015 at 6:33 PM / IP Logged
Snip the loop, and make sure all doors are closed. If they aren't it won't remote start
Ted
Compustar Expert
