2002 grand prix brake lights constant on
geeteezee
Member - Posts: 14
Posted: January 08, 2015 at 1:39 PM / IP Logged
I have installed a Prostart CT 3471TW along with Express Kit Pkalll. Car starts fine but the brake lights stay on with engine running or off with key removed. Checked the correct wire (orange) connected to white at the brake switch.
Any ideas?
chev104275
Gold - Posts: 1,436
Posted: January 08, 2015 at 1:48 PM / IP Logged
I would have to guess that either you knocked the brake switch out of adjustment or it went bad.   If you unplug the switch do the brake lights shut off ?    Also the car shouldn't remote start with the brake lights on so I would have to say you have the wrong wire.
geeteezee
Member - Posts: 14
Posted: January 08, 2015 at 1:54 PM / IP Logged
Out of adjustment. It must have happened after the initial test. Works fine now and shuts down with brake applied.
Thanks for your help!
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
