alarm sirens keep failing
paradox_108
Member - Posts: 48
Posted: January 11, 2015 at 2:54 PM / IP Logged
Hey guys.
I've fitted a dei 3903t canbus upgrade system to my car and I've replaced 3 sirens already. Some how they just keep failing after a month or two.
Any of you guys have any suggestions of what could be going wrong ??
Platinum - Posts: 13,725
Posted: January 11, 2015 at 4:22 PM / IP Logged
Are they mounted above the exhaust manifold? Is it aiming downward to prevent water from filling the bell up with water?
paradox_108
Member - Posts: 48
Posted: January 11, 2015 at 8:12 PM / IP Logged
the sirens were all aimed downwards. the siren is mounted on the strut tower well away from the exhaust manifold.
I cant think of anything that maybe killing the sirens. They were all battery backup sirens.
tedmond
Gold - Posts: 4,610
Posted: January 11, 2015 at 9:53 PM / IP Logged
ive had bad batches of backup sirens before, maybe you just happen to get one?
Ted
Compustar Expert
Posted: January 11, 2015 at 10:09 PM / IP Logged
Or 3
tedmond
Gold - Posts: 4,610
Posted: January 11, 2015 at 11:00 PM / IP Logged
i am an idiot wrote:
Or 3
alarm sirens keep failing -- posted image.
i would like to say the lead acid batteries in those won't last long with excessive vibrations. i would relocate them far away from heat/strut tower
Ted
Compustar Expert
paradox_108
Member - Posts: 48
Posted: January 11, 2015 at 11:30 PM / IP Logged
I don't think it could be a bad batch.. sirens came from 3 different manufactures. I'm more leaning to heat as being the issue. but cant say for sure. I'll just wire it up to the horn to eliminate further issues
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
