excalibur 1850 remote start, wont unlock
azamora619
Member - Posts: 40
Posted: June 18, 2015 at 5:44 PM / IP Logged Link to Post Post Reply Quote azamora619
Hi I started to have an issue with the Excalibur 1850, everything works, except that it wont lock or unlock the doors, when alarms lock or unlock buttons are pushed you the alarm unit makes a clicking sound? what could be the issue. this alarm is installed on a 2002 explorer. any help would be appreciated. thank you...
Knowledge is Power.
azamora619
Member - Posts: 40
Posted: June 18, 2015 at 8:36 PM / IP Logged Link to Post Post Reply Quote azamora619
Hello everybody, after inspecting every wire connection, found out that the lock and unlock wires were corroded to the point where they were shorting out. some how water got into the wire way, right under the driver kick panel where the connections were made... got everything dried, replaced wires and walla problem solved..
Knowledge is Power.
