Ignition sense to power relay?
darkmice
Posted: October 03, 2015 at 8:55 AM / IP Logged Link to Post Post Reply Quote darkmice
Hello and forgive me if this has been posted before I searched and couldnt find anything about it.
I want to install my Escort hard wire kit into my Dodge Dart but like with all the newer vehicles finding an accessory wire is like a finding a needle in a haystack.
According to the DEI wiring information it states the accessory wire is (-) but for accessory sense only.
My question is can this be used to power a relay or has anyone tried it?
85 - the (-) accessory sense wire
86 - 12 volt
87 - 12 volt
30 - Output
Posted: October 03, 2015 at 9:54 AM / IP Logged Link to Post Post Reply Quote howie ll
Theoretically that should work.
Don't you have an (+) ignition wire, say at fusebox you can use, removing the need for a relay?
Platinum - Posts: 13,725
Posted: October 03, 2015 at 10:30 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Are you trying to put a radio in a chrysler vehicle?
Posted: October 03, 2015 at 10:31 AM / IP Logged Link to Post Post Reply Quote howie ll
Radar detector Craig.
Ween
Platinum - Posts: 1,368
Posted: October 03, 2015 at 1:54 PM / IP Logged Link to Post Post Reply Quote Ween
Is there a power outlet in the console? Mopar shows a pink / YELLOW as a fused ignition/accessory there.
darkmice
Posted: October 04, 2015 at 8:54 AM / IP Logged Link to Post Post Reply Quote darkmice
The (+) ignition wire says its ignition sense only and I thought the power outlets were all constant but ill check again. Thanks for the help.
Posted: October 04, 2015 at 11:20 AM / IP Logged Link to Post Post Reply Quote i am an idiot
I do not know about the Dart, but it is common practice for Chrysler to have 2 positions for that fuse in the fusebox. One position is constant and the other will provide switched power to the outlets. Read the last post in this thread.
https://www.the12volt.com/installbay/forum_posts.asp?tid=139478
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
