04 F150 dealer installed remote start
prostreet68
Member - Posts: 7
Posted: November 30, 2015 at 1:14 AM / IP Logged Link to Post Post Reply Quote prostreet68
Dealer installed Code remote start quit working on my F150.
When you push the button it beeps twice and something under the dash clicks but it doesn't even try to start. I read somewhere that two beeps is the hood switch but I took it off and tested it. The hood switch works just fine. Anyone familiar with these?
chev104275
Gold - Posts: 1,436
Posted: November 30, 2015 at 9:29 AM / IP Logged Link to Post Post Reply Quote chev104275
It's either hood switch or its seeing 12v on the brake wire. Disconnect one at a time to test it will start and run with either one disconnected. The only other thing I've seen is a bad DNA chip.   Make sure you don't leave anything disconnected. Both those are there for safety.   Just for testing purpose.
prostreet68
Member - Posts: 7
Posted: November 30, 2015 at 10:45 AM / IP Logged Link to Post Post Reply Quote prostreet68
Brake light switch is working and connected still too. I noticed the light is always blinking. Even when the key is in the ignition and the truck is running. Never used to do that.
chev104275
Gold - Posts: 1,436
Posted: November 30, 2015 at 12:12 PM / IP Logged Link to Post Post Reply Quote chev104275
What light is blinking ?
prostreet68
Member - Posts: 7
Posted: November 30, 2015 at 12:21 PM / IP Logged Link to Post Post Reply Quote prostreet68
The one in the dash for the remote start.
chev104275
Gold - Posts: 1,436
Posted: November 30, 2015 at 1:12 PM / IP Logged Link to Post Post Reply Quote chev104275
I'm guessing this is the 4 button square remote ? Try disconnecting one or both of the wires mentioned see what happens. My notes are at home right now. I would have to look what else or might be. Is this a new install or existing ?
Also after disconnecting the wires check to make sure nothing is shorted (hood wire to ground) ( brake wire to12v). Both Should be open
prostreet68
Member - Posts: 7
Posted: November 30, 2015 at 1:49 PM / IP Logged Link to Post Post Reply Quote prostreet68
Yeah. 4 button remote. Existing install that quit working.
I will try the brake light later. I tried the hood switch before.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
