2011 Sierra/Evo All and That-GM4
ziggyb222
Silver - Posts: 593
Posted: December 19, 2015 at 10:05 AM / IP Logged Link to Post Post Reply Quote ziggyb222
Doing a stand alone with the Evo All and the Thar-gm4 t-harness... Plugged the t-harness in... had already updated the module and selected the 3x lock.. held the program button..plugged in the four pin..selected the blue..plugged in the rest of the connectors.. solid blue...ignition on...flashing blue..program button once..the yellow /red alternating..ignition off...DCryptor completed successfully... connect all the connectors...4 pin last... no start..not even any dash lights... Any Ideas???? Thanks!!!
ziggyb222
Silver - Posts: 593
Posted: December 20, 2015 at 9:02 PM / IP Logged Link to Post Post Reply Quote ziggyb222
FYI.... OEM remote monitoring needs to be turned on in the options menu!!!!! DUHHHHH ME!!!!!
ziggyb222
Silver - Posts: 593
Posted: December 22, 2015 at 1:21 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Everything on the EVO-ALL 3x lock starter works as it should. Only thing is are the park lights. Outside in the day the parking lights do not come on while in remote start. The lights are set to auto...and inside all lights come on because it is dark enough. Connected the BROWN / White from the EVO to the Light blue at the switch... Any ideas to make the parking lights come on outside????
ak609
Member - Posts: 47
Posted: December 22, 2015 at 4:10 PM / IP Logged Link to Post Post Reply Quote ak609
i would test the brown white wire to make sure the evo piece is doing the right thing along with test the light blue wire at the switch to make sure its the right one.
ziggyb222
Silver - Posts: 593
Posted: December 22, 2015 at 5:17 PM / IP Logged Link to Post Post Reply Quote ziggyb222
I will have the truck again tomorrow to double check that... and go into the options on the EVO and check them. I thought maybe the auto lights had something to do with it... Thanks
ak609
Member - Posts: 47
Posted: December 22, 2015 at 9:17 PM / IP Logged Link to Post Post Reply Quote ak609
looking further into it looks like it is a relay inside there were the yellow black wire is the input while the brown white is the output. so make sure the yellow black is connected to ground
ziggyb222
Silver - Posts: 593
Posted: December 22, 2015 at 9:39 PM / IP Logged Link to Post Post Reply Quote ziggyb222
AAAHHHHH... I did not even pick up on that... It has been awhile since I used the Fortin stuff... Thanks for your help...Merry Christmas!!!
ak609
Member - Posts: 47
Posted: December 25, 2015 at 5:35 PM / IP Logged Link to Post Post Reply Quote ak609
merry christmas to you to sir!!! hope it all worked out.
